Possible To Change Paint Sheen? - Painting - DIY Chatroom Home Improvement Forum
Old 07-06-2009, 07:48 AM   #1
Possible to Change Paint Sheen?
I strongly suspect that the answer to this question is "no" but I'll ask anyway.
My wife recently purchased several gallons of paint, all custom mixed, for a variety of projects we are working on over the next month or so. By mistake, she purchased flat paint for all the walls rather than the eggshell or satin that we had been planning on using. Since these are custom mixed, they can't be returned so my question is whether there is something that can be added to the paint - standard latex interior - that will bump the sheen from flat to something slightly glossier.
Thanks,
jlc
jlc791 is offline   Reply With Quote
Old 07-06-2009, 12:25 PM   #2
NAV
no, you are stuck with flat paint. you can use it as your first coat and paint over it with a new gallon of material in the sheen you wanted but i would not recommend that for trim work.
NAV is offline   Reply With Quote
Old 07-06-2009, 12:56 PM   #3
Thanks for the confirmation. Fortunately this is just for the walls so not a huge deal. The trim paint is all semi-gloss.
jlc
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
