Porch Floor Paint Chipping - Painting - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 07:57 AM   #1
Porch floor paint chipping
Our newly painted (latex) porch floor paint is already chipping. When we repaint it, can we apply a coat of polyurethane over it to keep it from chipping so easily?
AMThompson is offline   Reply With Quote
Old 09-23-2010, 09:15 AM   #2
Chipping floor paint
A protective coating could help but it might make it worse... I the paint failing to the previous coat or is it going down to the wood? If you painted over a finish that was not sound in the first place often that new layer will cause the previous layers to fail. Causes for paint to not stick are, moisture, low quality material, surface was dirty or dusty, surface was glossy. Your best bet would be to remove all failing material (potentially striping to raw wood) and use a quality enamel that is designed for floors, such as Sikkens Rubbol, I like the Oil Rubbol but here in Portland Oregon they are not selling it any more and it is being replaced with the water based version. I have we have used it on several project this summer, but will have to wait and see how it performs.
Good luck!
www.PearlPainters.com
Pearl Painters Portland Oregon
Pearl Painters is offline   Reply With Quote
Leaking Roof Where House Meets Porch tazmajazz Roofing/Siding 7 08-25-2010 06:18 PM
New Circuit to outside front porch - need help Leah Frances Electrical 12 05-13-2010 03:12 PM
How to Winterize Porch subdude Remodeling 0 02-04-2010 09:00 PM
How to rebuild a porch with a roof? redblotoflife Carpentry 2 11-23-2009 04:35 AM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 06:54 AM
