Old 08-29-2005, 11:14 PM   #1
porch floor
This post hasn't had any takers over in flooring, maybe somebody over here wants to tackle it...
I want to refinish my front porch floor, and was considering staining it. The floor is painted wood and is in good shape.
What I'm wondering is will stain with a topcoat be enough to properly seal the floor so it doesn't leak into the storage rooms below? Also, will the floor be too slippery?
What do you think?
slowpoke is offline   Reply With Quote
Old 08-30-2005, 07:57 AM   #2
Tired, Cold, and Damp
slickshift's Avatar
porch floor
The paint will have to be completely removed before staining
It's not an easy task and not a DIY project that I would recommend off-hand
Is the porch enclosed at all? Screens, actual walls?
slickshift is offline   Reply With Quote
Old 08-30-2005, 11:09 PM   #3
porch floor
I realize that I'm going to be knee-deep in paint dust, but I'm going to have to sand the floor regardless of the finish.
There is a ceiling/roof over the porch, as well as a partial brick wall surrounding it; however the rain and snow still find their way onto part of the porch.
Old 08-31-2005, 08:13 AM   #4
slickshift's Avatar
porch floor
Hmmm...
I'd suggest an exterior stain then
And being a floor you'll need something beefy
I'd consider it a "deck" and use deck stain
I can't tell a few things from here, so I can't tell you about the leaking into the storage
I can tell you that if the "floor" doesn't leak, no cracks or spaces, then the deck stain will seal it just fine
Use a good one though
I'd suggest Cabot, but there or other good ones
Usually in cases like this I use Ben Moore Patio Enamel, but that's a paint
If I think of something I used before in a case like this I'll post back
I don't think I've stained a patio in a loooong time
Old 09-05-2005, 12:51 AM   #5
porch floor
thanks for the feedback, slick.
I know staining a porch is unusual, but that's part of the appeal to me.
More On This Topic
Building a deck can be done with several types of wood for the floor planks including cedar, mahogany and driftwood. Depending on the area of the deck, make sure to get the right type of wood for each part with tips from a deck repair specialist in this... Read More »
Removing and cleaning stains from a wood floor can be very difficult, get expert house cleaning and house keeping tips in this free video. Read More »
If vinyl flooring gets stained, make a paste with laundry detergent and water to scrub into the stain. Spray water on a vinyl flooring stain to rinse the area after it's been cleaned with help from a professional house cleaner in this free video on... Read More »
Learn how to stain your backyard deck to keep it well maintained in this free video on deck care. Read More »
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
Porch rebuild question Unregistered General Discussion 1 11-26-2004 05:20 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
