Porch - Painting - DIY Chatroom Home Improvement Forum
Old 07-20-2012, 05:21 AM   #1
Porch
I need some help on painting my porch deck railing.... Need some tips! Also needed help painting my front door black to a different color to match my pink siding to my house.. It doesn't match.. I'm so duh about colors... Thanks.
deb789 is offline   Reply With Quote
Old 07-20-2012, 10:18 AM   #2
Too Short? Cut it Again!
It looks like the railing is new and not treated? I ask because if it is treated, and depending on the treatment, you may not be able to finish it for 6 months or so. Assuming it is good to go...
You might consider using a quality solid color stain instead of paint. Sherwin Williams Woodscapes Acrylic (water based) would be my choice and you can have it tinted to any color. It does not require a primer although you may want to shellac knot holes, etc. I think they are running a sale now too.
If you decide to paint it, you will need to seal/prime the wood first. I would use Benjamin Moore Fresh Start Alkyd (oil-based) primer but a quality latex acrylic bonding primer would work too. Follow with two coats of quality exterior paint finish.
Painting will go fairly fast with a thick nap mini-roller and a nice angled sash brush. Sometimes doing the posts a different shade or color can add a lot of character for very little effort.
I think we need more information about the front door. What is it made of and is it painted now or is the color in fiberglass or something? If painted do you know what with? There is a glass storm door in front of it? I know you do not like the color but is the finish on the door holding up alright? Some times the space between storm doors and entry doors can get savagely hot.
Old 07-20-2012, 01:22 PM   #3
Porch
What the best Deck stain to get? Where can i purchase it?
Old 07-20-2012, 04:06 PM   #4
Why are you looking for deck stain? Isn't that concrete I see in the photo? As mentioned, Sherwin Williams Woodscapes Acrylic would be a good choice for a solid color stain for the railing.
I don't think a semi-transparent stain will look good for the railing since it is so close to the house. If you must, I guess Cabot's or Sickkens would be good choices.
Just stay away from box store products.
Plans for Retrofitting Concrete Porch - Advice? BSponz1 Concrete, Stone & Masonry 1 05-07-2012 08:35 PM
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 12:14 PM
Porch Flooring Recommendation RyanS. Flooring 0 04-16-2011 11:31 AM
How to Winterize Porch subdude Remodeling 0 02-04-2010 09:00 PM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 06:54 AM
