Old 05-30-2009, 11:43 PM   #1
Question
Popcorn Walls
I have just moved into a rental unit that has popcorn walls throughout. I am familiar with popcorn ceilings but have never seen interior popcorn walls. Every single wall in the house is white and I really need to paint. I've read a few threads on popcorn ceilings but I need some help with walls.
Thx
mschrys2003 is offline   Reply With Quote
Old 05-31-2009, 06:50 AM   #2
paper hanger and painter
chrisn's Avatar
Popcorn Walls
What kind?
Old 07-06-2009, 03:23 PM   #3
Popcorn Walls
double post
n0c7 is offline   Reply With Quote
Old 07-06-2009, 03:24 PM   #4
Popcorn Walls
I've seen popcorn on walls before but usually it's painted over to make it durable. I couldn't see anyone spraying on popcorn and not painting it on vertical walls as it would very very easily flake off. If its painted already(you can't pick the popcorn off with little effort) then I would say just go ahead and paint.
Old 07-06-2009, 07:07 PM   #5
long island, NY
Popcorn Walls
also, don't try to remove it... besides it being messy to do, the popcorn is likely is hiding many wall surface imperfections. Just use a roller for rough surfaces and you should be fine... Good luck!
diy'er on LI is offline   Reply With Quote
Tags
popcorn, walls
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 03:43 PM
Straightening Racked Walls smitty286 Building & Construction 3 03-11-2008 09:35 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 03:50 PM
