Popcorn Texture - Painting - DIY Chatroom Home Improvement Forum
Old 05-28-2009, 07:12 PM   #1
popcorn texture
How would you remove painted popcorn texture from a ceiling?
Crystal is offline   Reply With Quote
Old 05-28-2009, 07:30 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
No matter how you slice it...it's messy
Basically, wet and scrape
If it's not been painted much, it'll fall off in blobs
If it has been painted a lot, it'll take more wetness and scraping
Either way...it's messy
What you'll have left will need sanding
And most likely much joint compound to repair it, as you may have damaged some during removal, and popcorn was almost never applied over a perfect surface anyway (it was used mainly to hide imperfections and mostly to reduce the effort of actually needing to have a good drywall job, at least compared to smooth walls, anyway)
Usually it is well worth the effort, which is just that...effort
And a willingness to get messy
No super special skills are needed
Just a willingness to wet, scrape, and sand (and get messy), and then some patching/smoothing (and sanding) with joint compound
Some of these types of project require more of all mentioned than others
It is impossible to say from here, or even until one gets into it, which yours is
slickshift is offline   Reply With Quote
Old 05-28-2009, 07:44 PM   #3
In my hallway I dry-scraped the ceiling
It still had a light texture to it as this did not remove the full coating
I liked the look & gave it a coat of paint
Depends upon the look you want
popcorn texture question kenmac Building & Construction 8 02-27-2009 03:22 PM
Removed popcorn ceiling, now how to texture? mikereno1 Remodeling 7 02-23-2009 07:05 PM
scraped popcorn - any tips before i texture? norcalsurfer1977 Painting 5 01-11-2009 03:25 PM
Trends in 2009: POPCORN TEXTURE IS BACK! studiobarb Interior Decorating 11 09-02-2008 06:26 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
