Popcorn Ceiling (resurfacing) - Painting - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 09:55 PM   #1
Rewards Points: 14
popcorn ceiling (resurfacing)
Hello all,
We recently purchased a house and wife surprised me with a honey-do list of removing the popcorn ceiling. Well, so far, Ive scraped one room, it came down like it was expected. The other rooms, its a battle between getting the popcorn and scraping the drywall.
Since we dont have a smooth surface, we decided to use spackling paste and just create a smooth surface. Is this the right material? Its a slow and long process of spackling and sanding. And repeating.
bryanp is offline   Reply With Quote
Old 08-23-2011, 11:07 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
No, it isn't.
After getting the popcorn off, if it is real dusty I will give it a coat of Gardz, then use maybe 2 full skim coats (depending whats left) of a premixed like Plus 3. Sands pretty easy.
Prime, check over and spot mud as needed, reprime those and paint.
The other thing most DIY don't get us use a wide blade. Most of it should be done with a 12" blade. Thin the bucket just a little bit , but it should be like real thick pancake batter.
Brushjockey is offline   Reply With Quote
Old 08-23-2011, 11:26 PM   #3
Rewards Points: 14
Spot mud with the "Plus 3"? I do have the wide blade. I think its about 12" I have a trowel?, that I can put the mixture into and work on to the blade to apply to the ceiling.
Whats the difference between what Im using and the "Plus 3" product?
Old 08-25-2011, 06:16 AM   #4
m1951mm's Avatar
This seems to be a good place for a new thread explaining the difference between spackle and joint compound or other products that will even out a surface.
I'll start the thread. Need the pro's to follow in with all the BEST answers. I have some but not always the best.
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
popcorn ceiling andybell Drywall & Plaster 2 09-13-2010 12:55 PM
Popcorn ceiling removal and retexturing lexter_wolf General DIY Discussions 2 05-09-2008 06:51 PM
popcorn ceiling removal and retexturing lexter_wolf Carpentry 1 05-09-2008 08:07 AM
Retexturing painted popcorn ceiling kwehnes Building & Construction 6 01-02-2007 05:36 AM
Question about popcorn ceiling J187 Building & Construction 4 06-30-2006 02:33 PM
