Popcorn Ceiling Questions - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-01-2013, 10:51 AM   #16
ccarlisle's Avatar
Well, Toolseeker, what do you do?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 03-01-2013, 11:41 AM   #17
Rewards Points: 5,974
I either use Gardz or oil based to seal then paint, from exp. I don't take the chance of water based. I guess I should also say I try to spray the Gardz or oil. The gardz whice is best can even be sprayed with a pump up sprayer.
Old 03-01-2013, 11:44 AM   #18
^^ Just saw that toolseeker replied while I was writing this saying almost exactly the same thing but here is my opinion anyway...
I would just use Gardz and then any kind of paint on top of that. Almost 0% chance of failure, fairly minimal additional cost or work. You could even spray it out of a garden sprayer if you wanted to get really adventureous. It says you can in the product documentation, although I have never tried. Unless you can confirm that the ceiling has already been painted once with no ill-effects, I don't see any reason to take the chance with using water-based right away.
Even better - scrape it off, skim coat, and get a flat ceiling! Tons of extra work but no more horrid popcorn.
Zyme is offline   Reply With Quote
The Following User Says Thank You to Zyme For This Useful Post:
ToolSeeker (03-01-2013)
Old 03-01-2013, 11:59 AM   #19
Rewards Points: 4,780
You don't seem to understand what I'm saying. I agree with you. You're asking is it worth the chance to roll latex on your ceiling? The problem is most homeowners don't realize there is any risk because they're not informed and certainly don't watch this forum. So they just do it with latex paint. When it works, they don't think any more about it. When it doesn't, they call you. I'm not claiming it's worth the risk, I'm simply claiming that painting the ceiling with oil is rare.
jeffnc is offline   Reply With Quote
Old 03-01-2013, 02:05 PM   #20
cdaniels's Avatar
I agree with Brush I have always used latex on popcorn ceilings and it usually holds tight.It's sometimes does pull loose but definitely not always.It's not the norm.I also have had to stain kill ceilings with oil base on occasion and have had them come off in spots too.If it's gonna pull loose anything will pull it off.If the ceilings been painted before it is definitely easier to paint because it's sealed and doesn't soak paint up so much.Stay out of it while it's wet and you should be fine.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Question re. painting walls & ceiling with smooth trim alongside popcorn ceiling *pic starrysim Painting 17 07-29-2012 10:02 AM
Best roller to use with B-I-N on Popcorn Ceiling? AlaskaChick Painting 12 07-01-2012 11:38 AM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 10:27 PM
Another popcorn ceiling question! HOW? Astrovel Painting 21 11-12-2010 10:19 PM
Hanging Drywall to a finished Ceiling, Seam Questions? Worker-B Drywall & Plaster 5 08-24-2009 10:40 AM
