Polyurethane -- Wait Time Before Between-coats Sanding - Painting - DIY Chatroom Home Improvement Forum
Old 12-09-2015, 01:36 PM   #1
tiger1964's Avatar
Rewards Points: 96
Polyurethane -- wait time before between-coats sanding
Getting a second coat on this evening. How long until I can lightly sand so I can proceed recoating? How hard/dry is hard/dry enough? Normally I'd like to wait a couple of days, but circumstances are such that I'd like to move forward.
Minwax high-gloss oil base poly on stained new wood, room temp, last time I checked 43% humidity where I'm working. Room oriented south-southwest, 148' above sea level.
tiger1964 is offline   Reply With Quote
Old 12-09-2015, 02:08 PM   #2
Rewards Points: 5,336
Didn't the container come with instructions? You should follow the instructions that came with your product. Water based differs from oil based and Minwax might differ from another manufacturer.
Ron
B. Franklin 1759
The Following 2 Users Say Thank You to Ron6519 For This Useful Post:
CompleteW&D (12-09-2015), joecaption (12-09-2015)
Old 12-09-2015, 02:27 PM   #3
CompleteW&D's Avatar
Rewards Points: 524
I agree totally with Ron. What do the manufacturer's directions say???
CompleteW&D is offline   Reply With Quote
Old 12-09-2015, 11:02 PM   #4
blackjack's Avatar
Rewards Points: 108
Echo, echo, echo....follow manufactures instructions. (or you'll be sorry)
blackjack is offline   Reply With Quote
Old 12-09-2015, 11:04 PM   #5
Rewards Points: 372
rushing a poly job is a poor idea. if summer temps here in colorado, I'll wait 24 hrs between coats. winter time, 48 hrs +. otherwise you risk a coat which is wavy, and poly is a pita to strip back.
1acre is offline   Reply With Quote
Polyurethane Curing Time? 1simple Flooring 2 01-03-2011 06:11 PM
BM Impervo Waterbase: Sand Between Coats? Lovegasoline Painting 0 06-10-2010 02:11 PM
My Hardwood Floor Refinishing project roxksears General DIY Discussions 3 11-13-2009 05:43 PM
oil vs water poly batwoman Flooring 6 09-30-2008 10:00 PM
Time between coats of paint/primer joeyboy Painting 19 09-23-2007 09:15 AM
