Polyurethane Over Stone Effects Paint - Painting - DIY Chatroom Home Improvement Forum
Old 02-09-2011, 03:22 PM   #1
Polyurethane over stone effects paint
I have ugly blue formica countertops but cannot aford to replace them. I would love to have stone countertops. My question is, can I paint them with a stone effect paint and then polyurethane over it to give me a smooth durable surface to work on that is food safe? I love to cook and so so quite often, plus my small children grab stuff off the counter to eat all the time and I want to make sure that it will be safe.
Any help will be greatly appreciated!
Thank you,
Mandy
amandamd is offline   Reply With Quote
Old 02-10-2011, 04:56 AM   #2
Hi Mandy, You can paint over formica and I know there are products for that finish specifically. The problem lies in doing the proper preparation work to create a bondable surface for that finish. I would first use a palm sander with 120 or lighter grit sandpaper running it lightly over the surface enough to dull it a bit. (I've never sanded a counter like that so don't know about dust, but wear a mask and protect surrounding surfaces with plastic if so) Vacuum the surface. Then I would wash the surface with a mixture of trisodium phosphate and water and rinse. Then you need to buy a strong bonding primer such as Zinsser BIN or an XIM primer. Apply it carefully with a short nap roller. You now have a bonded surface and can apply any paint finish once that's dry. The primer may work without the sanding but I wouldn't take the chance. As to food safe clear coats, I'm sure a little research will find one. But, is anything really food safe? Good Luck.
Joe
DiyPaintingGuide.org
Tags
countertops , paint , polyurethane , stone finish
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
How to remove latex paint from stone pavers? dragonness Building & Construction 8 07-20-2008 10:12 AM
Best protective finish for old barn-board, used as table? BradG Painting 8 06-18-2008 12:30 PM
