Polyurethane Floor protection
Benjamin Moore's Oil-Based Porch, Floor and Patio paint is urethane reinforced (and the waterbased equivalent is epoxy reinforced). I assume this is similar to what you used?
Two coats are a good idea but more can create problems. Cured two coats should last you quite awhile so long as you prepped carefully before application. I would not try to topcoat a floor paint.
Try to let it cure completely before setting too much heavy furniture, shelving, etc. on it.
