Polyurethane - Painting - DIY Chatroom Home Improvement Forum
Old 02-13-2012, 06:52 PM   #1
polyurethane
Can I paint oil based polyurethane over latex based paint on ceramic tile???
Kathleen922 is offline   Reply With Quote
Old 02-13-2012, 08:36 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
So- The latex on the ceramic might already have an adhesion problem unless it was primed right, and you want to put a clear ? poly over it?
Why?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 02-14-2012, 07:16 AM   #3
Gymschu's Avatar
Rewards Points: 1,034
I would not do it. If you really have to put a clear coat on, use a water-based polyurethane.
Old 02-14-2012, 10:48 AM   #4
Mr. Paint's Avatar
I agree, Gym. Oil-based polyurethanes have ab amber cast and continue to yellow, discoloring what you are trying to protect. Zar or Varathane (And others) offer water-based polyurethanes that will perform better for this purpose.
Mr. Paint is offline   Reply With Quote
Old 02-14-2012, 11:20 AM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Where is this ceramic tile and have you put down the latex paint yet?
If these are pukey pink 50's shower tiles, don't even go there. It wont last. It will peel and look worse that what you have.
Old 02-14-2012, 01:50 PM   #6
Gymschu's Avatar
Really good point, Blondsense. Nothing looks worse than painted tiles, especially when they start to peel, chip, etc.
Old 02-14-2012, 02:45 PM   #7
BraniksPainting's Avatar
So we can better assess the situation, please tell us if the ceramic tile is already painted or if you plan on painting it.
BraniksPainting is offline   Reply With Quote
Using Aerosol Polyurethane to finish doors? roxksears General DIY Discussions 4 11-07-2010 05:16 PM
Particles showing through the polyurethane over my newly-sanded hardwood floors proofer Flooring 3 12-10-2008 08:42 AM
oil vs water poly batwoman Flooring 6 09-30-2008 10:00 PM
Minwax Polyurethane vs. Minwax Polyurethane Floors proofer Flooring 3 04-06-2008 08:48 AM
Staining Wood Floor -- Use Polyurethane or FLOOR Polyurethane? proofer Painting 2 04-05-2008 07:47 PM
