Polyurethane - Painting - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 01:31 PM   #1
Polyurethane
Is there a tip in removing brush stroke lines when Polyurethane im using a good brush sanded in between coats just can't seem to get rid of a few brush lines
Don Smith is offline   Reply With Quote
Old 04-04-2011, 03:40 PM   #2
I assume your using water based polyurethane?
Problem with polyurethane is that they harder to repair. The only way to remove it is to strip it off and start over or sand.
StevenH is offline   Reply With Quote
Old 04-04-2011, 03:49 PM   #3
I'm using oil base and thinning it with mineral sprits.
Old 04-04-2011, 03:58 PM   #4
Is a foam brush better to use than a bristle brush
Old 04-04-2011, 05:24 PM   #5
Oil base polyurethane are even harder to fix than water base.
First of all how deep it brush strokes?
Too deep, it will be dificult to sand leveled.
If you can post photos, it would be helpful
The problem I see people do is they over brush, not letting it flow itself. This cause brush strokes to shown when dry.
Apply it once, backbrush once or twice and move on.
Old 04-04-2011, 05:25 PM   #6
No, It is based on quality bristle brush and skill
Old 04-04-2011, 07:14 PM   #7
Well I have the best brush.... It must be my skill level It's a bar top on a tiki bar I built in my back yard just worked on it alittle while ago and it's really looking good I think over brushing was it Thanks..... Cheers
Using Aerosol Polyurethane to finish doors? roxksears General DIY Discussions 4 11-07-2010 05:16 PM
Particles showing through the polyurethane over my newly-sanded hardwood floors proofer Flooring 3 12-10-2008 08:42 AM
oil vs water poly batwoman Flooring 6 09-30-2008 10:00 PM
Minwax Polyurethane vs. Minwax Polyurethane Floors proofer Flooring 3 04-06-2008 08:48 AM
Staining Wood Floor -- Use Polyurethane or FLOOR Polyurethane? proofer Painting 2 04-05-2008 07:47 PM
