Polycrylic Streaky!! - Painting - DIY Chatroom Home Improvement Forum
Old 06-23-2012, 09:34 PM   #1
Polycrylic streaky!!
I really need some advice. I've refinished furniture many times and never had this problem.... I brushed on the poly and it dried quicker than normal. Maybe because temperatures were in high 80's and worked in garage? Regardless, the finish is very streaky. Is there anything that can be done to smooth it out? Also, can you recommend a different, better finish for next project?
Thanks!!
CindyBechtel is offline   Reply With Quote
Old 06-24-2012, 06:16 AM   #2
DIY staff
Rewards Points: 7,174
Polycrylic (colored varnish) is the most difficult finish I have ever used---
Any lap marks or thick spots in the finish are darker than the surrounding area---
Next time---use a regular wood stain like Minwax ---then a clear coat on top of that---
A brush on Polly or water based poly would be my choice---I use a lot of wipe on poly---often as the base coat for a brush on--or as the finish coat if I want a hand rubbed look.
Good luck with the colored varnish---I hate that product---very difficult to get a fine finish using it.---Mike---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
BigJim (06-24-2012), CindyBechtel (06-24-2012)
Old 06-24-2012, 06:45 AM   #3
Rewards Points: 258
Hey Cindy,
On hot days like we’ve had acrylic finishes dry extremely fast especially succeeding coats after you’ve applied your first. The only suggestion I can offer is add a little Flotrol by Flood. I can’t say I’ve tried it in acrylic varnishes, however it works great in latex paints. I would say to add a little Flotrol to a small amount of Polycrylic (just a sample amount) and see how it reacts. It should slow down the drying time allowing you to a little more time to work it.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
The Following User Says Thank You to spraygunn For This Useful Post:
Old 06-24-2012, 06:51 AM   #4
DIY staff
I apologize---I was thinking of "Poly Shades" (colored Poly)
I'm not sure what Polycrilic is---must be a brand name---sorry--Mike---
Old 06-24-2012, 08:25 AM   #5
Sorry, I wasn't very specific. Polycrylic is a clear coat made by minwax. I applied over paint. I will try flotrol next time. But in the meantime, I have 3 pieces of furniture that are streaky and they are supposed to be in a trade show this weekend!! I'm slightly panicked. Is there anything I can do to correct the streaks? I've read about rubbing out finishes with steel wool or sand paper. Ive never used the rubbing out technique. Could that be an option to get a smooth finish? If so, would I need to apply another layer of clear coat afterward?
Old 06-24-2012, 08:33 AM   #6
Rewards Points: 13,748
Personaly I'd ever apply a sealer over any paint.
Use a tougher paint like epoxy or enamel and no sealer is needed.
Old 06-24-2012, 08:41 AM   #7
I completely agree. I've experimented lately with water based latex enamel from Sherwin Williams and the durability was an amazing difference. Unfortunately, I used regular latex in satin on these pieces so felt it needed a top coat.
Old 06-24-2012, 09:28 AM   #8
Rubbin walls since'79
Brushjockey's Avatar
Another possibility is that rarely but not unheard of- high humidity will cause it.
Getting it out of a clear coat might be tough.
BTW- also next time try Zar Ultra Max poly. easiest working clear I know of, and it's tough.
I think you can get it at Ace Hdwre among other places.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Old 06-24-2012, 09:34 AM   #9
Rewards Points: 258
Cindy,
Give it a light sand using some 220 paper and watch the edges so that you don’t cut through. Then apply a coupe coats of the Polycrylic with some Flotrol. The more you build up the millage the deeper the finish will appear and hide the streakiness. I’m assuming streakiness means brush marks. I finished a cradle with four coats of Polycrylic and it looked fantastic.
Best of Luck
Steve
The Following 2 Users Say Thank You to spraygunn For This Useful Post:
CindyBechtel (06-24-2012), oh'mike (06-24-2012)
Old 06-24-2012, 09:42 AM   #10
DIY staff
Yes,--Light sanding with 220 or 4 o (0000) steel wool--then a tack rag (sticky cloth) to remove any dust then another coat--the water based polys need to be applied a little heavier than you might think in order for it to flow together before it dries.
Old 06-24-2012, 10:28 AM   #11
Matthewt1970's Avatar
Rewards Points: 1,098
You can always tell when a floor is done with Polycrylic or any water based Poly. If you slide a piece of furniture you will now have some nice scratches.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
Old 06-24-2012, 03:18 PM   #12
Thanks for the tip on zar ultra max poly, will definitely try it out.
today, I sanded in between coats and now have 3 layers of polycrylic on. Looks better but not perfect. So I headed back to Sherwin Williams.
They suggested sanding then applying latex enamel with a sponge roller. This would give a smooth finish without having to apply a clear coat. They also added a floating agent, assuming flotrol or similar, to make it more workable. I tried it out on top of the desk, as it looked particularly bad. After 2 coats, sanding in between, there are roller marks. I was careful to not overlap much or use too much paint, and went in a straight up and down motion. The guy at Sw said if I wasn't happy with product to bring back and he would replace with oil based enamel. I do have a sprayer. Should I try that with the latex enamel or go get the oil enamel? This may be the longest, most costly, debockle of a project I've ever experienced! Any input is much appreciated!
Old 06-24-2012, 03:42 PM   #13
DIY staff
I feel bad for you----Painting requires some experience to learn how different paints flow and set.
If you have roller marks--I suspect that you are going to slow---
I wish I was there(or one of the painters)
You need to --first get the paint on the surface---then quickly stroke the entire surface flat before the paint 'flashes'---this way the entire surface is wet at the same time --and can flow together without brush strokes or roller marks---
I'm not good at describing the process--perhaps another painter can make it more understandable.
Old 06-24-2012, 04:06 PM   #14
I have actually found no good use for a foam roller- at all.
What mike is describing is my preferred method of doing larger flats- rolling it on just to get the material there faster, then with a very light touch "tipping " or "backbrushing" in long strokes to smooth out. I think roller stipple in a enamel or clear finish looks poor.
But these new finishes are not easy- I also prefer a company called XIM 's latex extender to flotrol- like grease for your brush. Sometimes just a tiny bit of water also. This is where experience with the material comes in.
It is a feel thing.
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
Old 06-24-2012, 06:00 PM   #15
I was rolling slow. Think I'm so paranoid and scared of another mistake was trying to be too precise. Plus, besides the roller marks, I wasn't thrilled with the stippling. So....I rolled, then tip brushed a corner for a tester and it looks pretty good....I finally see hope! Thanks everyone for your help. Through it I have learned one thing... I know way less about paint than I thought I did!! Will update tomorrow with developments. Hopefully positive
Blotchy & Streaky Refinish Job craymer45 Remodeling 4 09-25-2012 03:40 PM
Can I paint over Minwax polycrylic pomelo Painting 5 08-11-2009 11:42 PM
Streaky fence stain christieg Painting 12 08-04-2009 03:30 AM
Polycrylic on Pine Car Siding Rockypoint Painting 1 04-30-2008 06:52 AM
Polycrylic Sftail2 Painting 2 03-29-2008 04:29 PM
