Poly Took Off The Spray Paint Why? - Painting - DIY Chatroom Home Improvement Forum
Old 11-15-2012, 03:11 AM   #1
poly took off the spray paint why?
i put polyurethane over spray painted chrome and it took the spray paint off why?
cynthiacrisafi@ is offline   Reply With Quote
Old 11-15-2012, 04:20 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
Why?
Improper prep.
chrisn is online now   Reply With Quote
Old 11-16-2012, 11:16 AM   #3
Although I am not expert need more details, what is being painted, and primer, etc.......Since you indicated 'chrome' I was thinking metal
object being painted, could be wrong. I have had good luck painting metail door fixtures after sanding, cleaning, and applying a metal type primer.
I could be wrong but more details about the project would help. There are quite a few experts here that would chime in for you.
Good Luck!
pinkfloyd43 is offline   Reply With Quote
Old 11-18-2012, 12:31 AM   #4
Too Short? Cut it Again!
Those spray chrome finishes are specialty. Did you use the recommended primer for the material you were painting? Did the can say the finish could be clear coated? Did you use the recommended product?
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Spray painting a metal front door - what paint?? hayman Painting 9 09-22-2012 06:15 PM
Spray paint "lifting" underlying paint karlthev Painting 15 05-12-2012 06:56 AM
Painting patch in bathroom ohman Painting 4 09-15-2010 11:09 PM
