Old 09-16-2011, 01:28 PM   #1
Is this wire Hot?
Oh-Fudge's Avatar
To Poly or Not to Poly?
I am installing beadboard wainscoting and don't know if I should apply polyurethane over the paint for extra protection, or just use paint. If I can use poly, what is the best paint to put under it - flat, semi, gloss, other? Thank you.
Oh-Fudge is offline   Reply With Quote
Old 09-16-2011, 02:11 PM   #2
ltd
i like cover stain oil primer by zinnzer ,then top coat with pro classic acrillic ,or pro classic warter bourn alkyd in a semigloss by sherwin williams. oh to answer first question
ltd is online now   Reply With Quote
Old 09-16-2011, 02:49 PM   #3
Is this wire Hot?
Oh-Fudge's Avatar
ltd, I don't quite understand your answer. You're saying prime with oil base and paint with semigloss? No poly on top then?
This is a DIY project. The beadboard came pre-primed (white). I was hoping to stay water-based for ease of cleanup. I guess my main question is can I put waterbased poly over waterbased paint, and if so, is it really necessary? Thank you.
Oh, sorry, I just noticed the little head-shaking "no" icon on your post.
Old 09-16-2011, 03:42 PM   #4
No need to poly over top of paint. THe kinds of protection poly top coats give surfaces are already in the paint. I would use a water based primer followed by a water based paint.
Windows is offline   Reply With Quote
The Following User Says Thank You to Windows For This Useful Post:
Oh-Fudge (09-16-2011)
Old 09-16-2011, 04:53 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
I agree you don't need to clear coat it- just use a good satin/ semi finish. Beadboard is most often given the same treatment as wood trim- use a good primer, 2 top coats.
I like BM Waterborne satin impervo or BM Aura satin - Zinsser 123 or BM fresh start are good primers. Sand lightly between all coats.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Old 09-16-2011, 05:19 PM   #6
Is this wire Hot?
Oh-Fudge's Avatar
Thanks Guys! That's what I wanted to know
metal left in hardwood floor sealer deetu Flooring 26 06-16-2012 08:29 AM
Stain over Poly? megkatgre Flooring 3 04-27-2010 01:07 PM
Concrete and Poly Moisture Barrier Colby Building & Construction 5 03-31-2009 11:07 AM
poly on engineered hardwood floor? Constant Improvement Flooring 3 02-03-2009 12:09 PM
Poly interior doors gregrice Painting 4 05-15-2006 01:35 PM
