Poly interior doors
I just got, and stained, some knotty alder interior doors... beautiful. Question: Do I need to polyurethane them, should I poly them? If I do, it'll just be satin, but I suspect they'll be even more pretty w/ some poly. I just tried the wipe-on poly on a test subject and it seems kind of a pain, two coats. What are your considered opinions on poly/no poly, and what kind of poly for interior doors? Thanks, Greg |
I don't like poly on wood, personal opinion. I'm oil all of the way.
You consider 2 coats a problem? I'm thinking 3-4 min. on new wood whatever you use. The first few coats will just sink in. |
Thanks for the prompt reply. But sorry, when you say "oil" does that mean varnish, or the good ole stuff grandma used to treat furniture with? :) And how is it applied? Greg |
No, no, not unless you want to Quote:
I'd say 4 min with a wipe-on poly on new wood Possibly 6 for a good finish Quote:
On a professional note, I don't do a lot of poly over stain on doors/trim Not much at all Don't let that stop you if you'd like to do it It could be a seashore thing Trends can be a bit different here Like I'd almost swear there was a law passed that houses have to have white trim inside now Lol... |
| All times are GMT -4. The time now is 02:25 AM. |
