Old 01-01-2009, 06:49 PM   #1
pole sanding
What grit do you all use when pole sanding primer(zin 123, water based)?
I see 'medium' grit, which I think is 100, and 'fine', which is 150.
Thanks for the help.
7echo is offline   Reply With Quote
Old 01-01-2009, 07:13 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
pole sanding
Fine would be fine
slickshift is offline   Reply With Quote
Old 01-01-2009, 07:55 PM   #3
pole sanding
Appreciate the quick response. I wish they would just use the grit size.
Thanks again.
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 09:12 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
single pole vs. double pole circuits DannoW Electrical 7 07-21-2008 10:20 AM
How Does A Double Pole Circuit Breaker Trip? shadowx360 Electrical 2 07-09-2008 03:44 PM
Yet another distance from Pole and meter to house question urbanfarmer Electrical 9 05-25-2008 07:38 PM
