#1 |
please help
i took of the wallpaper and the third layer of wallpaper pulled off some of the drywall because it was attached directly to the drywall. I sanded the crap out of the walls and put on bulls eye 123 primer..after the first coat it is bubbling . any suggestions on what I should do? I know eventually i have to apply joint compound but i dont think i can apply it with all of these bubbles in the wall..can I?
#2 |
Pro Painter
please help
You should have used Zinsser's Gardz instead of the bullseye. You will have to take a knife and cut out the bubbling areas of paper, prime those areas with Gardz, skim them, sand them, then prime the entire wall with Gardz again, and finally apply your finish paint.
#3 |
please help
thanks for your help im going to get the guardz now......i hope this works....
#4 |
Pro Painter
please help
Do as I said and you'll be just fine.
#5 |
please help
thanks!!!!!!! it worked
#6 |
registered
please help
Sorry i lead you a stray. I was in the same stituation in my bathroom as you. The bullseye didn't bubble on my walls. I did however screen the walls after i primed and then a second coat. Thats what i also did. Bought the 5 gallon joint compound allready mixed and skimmed the walls.
| Display Modes | |
