Plastering - Painting - DIY Chatroom Home Improvement Forum
Old 07-31-2007, 11:56 AM   #1
plastering
im pretty new to the paint/ plaster business. i have a 1 question, is it just a matter of preference when plastering, to use a sponge, or to use sandpaper after applying compound? which creates a better finish? also does "hot mud" really make the compound mix stronger , or is it just a quick way to have your compound dry faster so you can apply 2nd coat?
nypainter is offline   Reply With Quote
Old 07-31-2007, 10:21 PM   #2
made in U.S.A.
Hamilton's Avatar
Use sandpaper. Maybe there's pros out there using sponges...I haven't seen any.
Hotmud is great for repairs and patching. I believe it is stronger than standard joint compound, at least it's harder to sand. Also, it's the only recommended mud for mesh tape.
People sleep peacefully at night because rough men stand guard to deal with violence on their behalf.
Hamilton is offline   Reply With Quote
Old 07-31-2007, 11:09 PM   #3
Paint/Faux Artisan
Da Vinci's Avatar
Don't waste time with sponges, use sand paper or better yet sanding screens because they don't clog with dust.
Hot mud is superior in so many ways- you can do two, three coats or more in a day. Biggest plus- it doesn't shrink like joint compound which dries by evaporation of water- water goes/ stuff shrinks. Hot mud is chemical cure- once mixed it will even harden under water.
Trick to using it- Use for taping, big patches, initial work. After sets- use putty knife and just scrape ridges/lines- don't sand. DO this for next 2 coats. Then use joint compound for topcoat only- smooths easier, sands easier.
Bay area Painting Company
Da Vinci is offline   Reply With Quote
Old 08-01-2007, 06:56 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You mean ''drywall/taping/coating''. There's a difference between "Plastering" and ''drywall''. My first suggestion is that you drop the term "plastering" when describing what you are starting out doing, you are going to confuse people.
- Build Well -
Old 08-01-2007, 05:06 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
I'm pretty sure you don't mean plastering also
It sounds like you mean using joint compound on sheetrock/drywall
Plastering could mean actual plaster as in plaster walls, or texturing that's done to walls
As you are talking about sanding it and hot mud, I'm assuming you mean joint compounding repairs on drywall
To answer th questions with that assumption, "wet sanding" or "sponge sanding" generally does not provide (even close to) the smoothness needed
Hot mud may be stronger, I don't know
I use it for it's drying speed
I generally use regular (light weight) for the last coat
slickshift is offline   Reply With Quote
Old 08-04-2007, 02:52 PM   #6
im pretty new to this
this is the terminology that alot of contractors in the n.y. area use. maybe its wrong, but yes im referring to applying joint cmpd
Old 08-04-2007, 10:16 PM   #7
Workaholic's Avatar
Sanding screens will work good if using for sanding coats of drywall.
Sean
Workaholic is offline   Reply With Quote
Old 08-05-2007, 08:17 AM   #8
Sorry to tell you this, but, if they are using that terminology (plastering) to describe performing ''drywall'', they are, in fact, wrong.
It could even lead to a lawsuit if a client were expecting "plaster" and got drywall instead....
- Build Well -
Old 08-13-2007, 07:41 PM   #9
montaillou's Avatar
For what it's worth, I read this thread specifically because it said "plastering" as I have a 1916 home and am considering remodeling my living/dining room with plaster instead of drywall. So, yeah, it can make a difference.
montaillou is offline   Reply With Quote
Plastering over paneling TNRocks Remodeling 13 01-14-2010 07:47 AM
Plastering help Plaster Brokers Introductions 8 02-01-2009 09:42 PM
plastering or drywall section? Plaster Brokers Site Help and Suggestions 0 07-27-2007 10:26 PM
Plastering Mix Liamsbab Building & Construction 3 05-29-2007 06:14 PM
Plastering on newly laid brickwork? djj66 Building & Construction 10 09-21-2005 01:01 AM
