Plasterboard Cracks - Painting - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 10:51 AM   #1
Plasterboard cracks
I have plasterboard in my home and in some areas there is fine spider-web type cracking which paint does not hide.
Are there any suggestions on what I should do to hide these cracks? Do I just skim coat the walls or do I need to put some type of mesh down as well?
dundeeslugger is offline   Reply With Quote
Old 01-07-2009, 01:40 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
I would just skim coat it. We run into a lot of the same with some of the older homes and a skim coat of joint compound, a coat of primer and then a coat of paint does the job.
Old 01-07-2009, 02:00 PM   #3
You don't have a problem with the cracks telegraphing through over time?
Old 01-10-2009, 02:25 PM   #4
Drywall contractor
Rewards Points: 1,070
If it's a problem with the drywall itself (or the joint compound), the proper way is to tape and mud, not just mud over the problem. It will come back eventually (maybe months later). Paper or mesh tape can be used. If you use mesh tape, use a setting type compound (powder mixed with water) for at least the first coat. You can use redimix for the subsequent coats.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Advice needed for filling large basement Cracks dgbehrends Building & Construction 11 11-17-2009 05:23 AM
Wedge cracks STG Building & Construction 4 07-01-2008 11:41 AM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 01:32 AM
Hole in wall w/ stress cracks... lots of detailed pics (NOT 56k connection friendly) Thaipo Building & Construction 8 05-21-2007 07:40 AM
Cracks in foundation....leaks....need some info. wackerjr Building & Construction 5 06-12-2006 02:15 PM
