Old 05-25-2009, 06:33 PM   #1
Plaster Wall Repair and Preparation
I pulled the wallpaper off of one of the walls in our new house today, and found a little more trouble than I had hoped for. The house was built in 1959, and I believe the walls are plaster. The "top coat" of the plaster (for lack of a better term in my vocabulary) has crumbled off. I believe there was some light water damage in the area at some point in the future before the windows were replaced by the previous owner. I have attached three pictures showing the situation and the surrounding area with the wallpaper removed. Can I just skimcoat the area to repair it, or is there a more in depth repair process? I will be painting the wall eventually.
Thanks so much!
Plaster Wall Repair and Preparation-img_0891.jpg   Plaster Wall Repair and Preparation-img_0892.jpg   Plaster Wall Repair and Preparation-img_0893.jpg
clrh is offline   Reply With Quote
Old 05-26-2009, 05:29 AM   #2
paper hanger and painter
chrisn's Avatar
Wet it down with a sponge and do your skim coats( probably3) maybe 4 . sand. clean and paint away.
Old 05-26-2009, 05:49 PM   #3
Chris - do you think maybe a coat of Plasterweld is called for? Looking at those pics it might be worth exploring. I'm wondering how "tight" the current plaster is. I don't think it could hurt to go over the existing wall with PlasterWeld, then skim coat
mazzonetv is offline   Reply With Quote
Old 05-26-2009, 06:07 PM   #4
Matthewt1970's Avatar
See if the plaster is crumbling in those spots. If it is not, thn that is a perfect surface to accept a few skim coats.
Old 05-27-2009, 05:56 AM   #5
chrisn's Avatar
I have never used it, as I think it is used for real plaster.I certainly could be wrong. I was talking about using joint compound.
