Plaster Showing Through Paint... Help! - Painting - DIY Chatroom Home Improvement Forum
Old 05-30-2009, 02:38 PM   #1
Plaster showing through paint... help!
After drywall'ing and taping my seams I primed and painted (tinted primer and deep blue paint).. But after a day of drying, I can still see the lines where I plastered.. Please tell me more coats of paint will cover this.. So far I did 3 coats over the "infected" area.
redpen is offline   Reply With Quote
Old 05-30-2009, 03:00 PM   #2
what type of mud? what primer and paint did you use? what sheen?(flat,eggshell, semi..etc)
newbpainter is offline   Reply With Quote
Old 05-30-2009, 03:47 PM   #3
mud - green cap - stuff from lowes
primer - valspar with a grey tint
paint - the level up from flat
Old 05-30-2009, 03:58 PM   #4
Myron Ferguson, in his book "Drywall", calls this problem "photographing."
Old 05-30-2009, 04:11 PM   #5
ok. so is there a solution?
Old 05-30-2009, 04:22 PM   #6
He said if it's already been painted, lightly sand using 150 grit sandpaper then paint with good flat latex paint then with the finish coat of paint.
http://books.google.com/books?id=lO8...esult&resnum=2
Old 05-30-2009, 05:59 PM   #7
Tired, Cold, and Damp
slickshift's Avatar
Hard to say from here
(can't see what's up really)
Could be your repairs weren't properly sanded/smoothed and primed
Could be your paint or tools or technique ain't up to snuff
Deep blues are tough...and could easily need 3 coats for a good paint (even if quality products, tools, and application techniques are used)
5-7 or more for a mediocre or poor paint (especially if inferior application tools and/or techniques are used) wouldn't be out of line
More specific information is needed to zero in on your issue
slickshift is offline   Reply With Quote
Old 05-31-2009, 05:53 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 298
especially if it was Valspar
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
