Plaster Ceilings/walls - Painting - DIY Chatroom Home Improvement Forum
Old 10-21-2008, 10:44 PM   #1
Plaster ceilings/walls
What primer is best on plaster? I would guess oil base. Any brands recommended?
Coon is offline   Reply With Quote
Old 10-22-2008, 06:28 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
To vague ,new old, why,painting ,wall papering??
Old 10-22-2008, 10:51 AM   #3
ccarlisle's Avatar
Look, there isn't one product that all painters know secretly as "the best primer" and that are "kept under their hats so that consumers won't find out about it". Each one has their favorites for sure but there are dozens of primers out there made for different situations.
If you want an idea of 6 of them, some of which we use, go to the Benjamin Moore website and look for the chart under 'Fresh Start' primers for an idea of what they recommend for different substrates.
I am sure the other manufacturers have the same, perhaps not on a website but somewhere.
In answer to your question, yes an alkyd primer is excellent on plaster...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 05:58 PM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 08:11 AM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
Plaster replacement lburele Building & Construction 1 04-29-2007 10:48 AM
Plaster removal decision Sarai Remodeling 2 09-08-2006 04:15 PM
