Old 04-17-2011, 02:41 PM   #1
plaster ? again
Previous owners painted over those plastic peices you insert in plaster walls to hang pictures. I pried out some, obviously left a hole. I used plaster patch to fill them, stayed slightly powdery in finish. Is that normal and fine to prime and paint over? Any other suggestions for removal of peices and filling?
LLJean is offline   Reply With Quote
Old 04-17-2011, 04:26 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
plaster ? again
I often will take a stiff putty knife and smack off the part that is higher than the surface, slightly tap whats left to set it a little deeper and then spackle ( might take 2 applications) . sand and spot prime, you're ready for finish.
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
ltd (04-17-2011)
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 01:06 PM
Plaster Walls? I dont know? chsitko Drywall & Plaster 4 08-28-2010 06:30 PM
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
