#1 |
Planning on painting interior of new construction home ~2500sq ft
Hi everyone just have a few question. My wife and I are planning on painting our new construction craftsman style home this fall. I just wanted to see what you guys prefer for the following areas. I do not have a paint sprayer so everything will have to brushed/rolled. Thanks
-Ceilings -Wood primer for trim -Trim Paint/Door Paint -Primer for bare drywall -Drywall Paint -Exterior paint for hardiplank |
#2 |
Rubbin walls since'79
Professional. get one.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS |
#3 |
Thanks for the reply. I guess shame on me for posting in a DIY forum!
#4 |
The reason I say that is there is so much here to know, and a new home is a huge investment. You are asking " what do I use to do it all"- Sounds like DIY would not be a great idea-
I work with remodel contractors and encourage them to advise their clients to not try and save a buck by painting /staining/ wood finishing themselves. most have no idea of the procedure and prep, they think "i'll get some paint, put it on- what's so hard about that." You will be looking at the finishing for many years. It is the most obvious part. I'm not trying to be a wise ass- think about it.
#5 |
paper hanger and painter
[quote=Brushjockey;935366]The reason I say that is there is so much here to know, and a new home is a huge investment. You are asking " what do I use to do it all"- Sounds like DIY would not be a great idea-
I work with remodel contractors and encourage them to advise their clients to not try and save a buck by painting /staining/ wood finishing themselves. most have no idea of the procedure and prep, they think "i'll get some paint, put it on- what's so hard about that." You will be looking at the finishing for many years. It is the most obvious part. I'm not trying to be a wise ass- think about it.[/quote] I agree,100%. If you need to ask those questions, it seems pretty obvious you do not know what you are getting into. The painting part is what you are going to have to live with. Get a pro that does this day in and day out and you will happier in the long run
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 |
You could pay to have everything primed, and even sprayed with flat white on top of that. Doing it on new construction is much cheaper because it's (relatively) much quicker and easier for a pro to spray everything before the floors and even possibly all the fixtures are in. Once you move in, if you want to DIY it all yourself, you can through at your own pace and do a room at a time. The color choices might be easier to make once your furniture and everything is in there, and your opinions on colors are likely to change in the "after" vs. the "before" move-in conditions also.
I'm thinking these guys are also right to recommend a pro for another reason: In addition to the assumed lack of experience, I have to also assume you probably don't have any supplies. Doing one room DIY at a time later, ad it's already "properly prepped" at this poimt, you can get by with smaller investments, i.e. a drop cloth, couple brushes, a roller, pole, and covers, some sandpaper, rags, and some tape, along with a gallon or two of your favorite color from Ben Moore (or your choice). Doing a whole house, new construction, you're going to need multiples of all of the above at the least, but you're going to wish you had a sprayer. You can rent one of course, but I assume you've never used one? However: If you do want to tackle this big job on you own, you should definitely visit your local paint store (not Lowes or Depot) with your list and measurements . They will guide you through the entire process of what to buy, how much to buy, and which direction to work in, and maybe even rent you a sprayer or refer you to a rental company that has one available. I'll try the DIY answer also -Ceilings- watorborne ceiling paint (it's white- but you can pick some colors if you wish) -Wood primer for trim - not sure if you're painting or staining, if this is interior or exterior, if painting, same primer as below -Trim Paint/Door Paint - Prime with Fresh Start Multi or Zinsser1-2-3, paint with Regal Select, Satin or Semi-Gloss (how much sheen u like?) -Primer for bare drywall - Fresh Start Muti-purpose Later Primer (or Zinsser 1-2-3) -Exterior paint for hardiplank - Fresh Start Latex Masonry or Zin 1-2-3, paint with with regal select exterior satin, or the "premium' Line (Moorguard Low Lustre -for all of your interior walls-->Regal Eggshell (and/or can use the Kitchen and Bath Paint if you prefer a satin finish in those particular rooms) So my opinion is clearly that I like Ben Moore Regal lines and Premium Exterior Line; I prefer eggshell on interior walls, semi-gloss interior trim, and satin / low lustre for the siding boards... Good luck with this big project - let us kno how it turns out... |
#7 |
Its just painting, not rocket science. Everybody paints, grandma, aunt lucy, kids, sometimes painting contractors think nobody can paint but them. Do a little research and it can be done correctly. Has grandma ever done any plumbing or electral work, or re roofed the house? Probably not, but anybody and everybody can paint.
![]() Yes i know, a pro is gonna do a better job, but if the homeowner ain't to picky they just might do it themselves. Last edited by ratchet; 06-10-2012 at 10:48 AM. |
#8 | |
Planning on painting interior of new construction home ~2500sq ftQuote:
#9 | |
no comment, it is not worthy of one
#10 | |
#11 |
..Somebody's been drinking the kool-aid..
#12 | |
Latex Primer: Good for Drywall, that's about it. Behr Paint: The plastic buckets are good, that's about it. |
#13 |
A guy who has painted for many years is for sure gonna do a better job, and do it quicker. But a Home owner can do it themselves if they got the time and patience. Roofers, plumbers, and carpenters can make more money then painters cause the HO can't do that kind of work, but they can and will paint there homes. You painters out there are workin' hard for your money and in the end the job looks better but ya all' got to admit that even your mom has painted a room or two. Don't think I don't respect painters cause I was one for over 25 years.
#14 |
The anybody can paint line has caused some of the worst problems .
Yes , anybody can get the can open and figure out a way to apply it. Some can do it pretty well. Some- not anybody. Some can't figure out which end of the screwdriver to use. And here is a mystery that the DIY runs straight into faster than they thought - VERY often, painting is not just about applying paint. Yes? We pros are here everyday to help "some" who can. Also to help those who are in over their head realize it before it's too late. THAT is also very valuable advice, me thinks.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS Last edited by Brushjockey; 06-10-2012 at 10:55 AM. |
| The Following User Says Thank You to Brushjockey For This Useful Post: | ratchet (06-10-2012) |
| Display Modes | |
| Planning to build First Spec Home, Need Advice | ahb2012 | General Discussion | 53 | 05-27-2013 07:30 AM |
| Planning to build addition on 2nd floor of home | J_Whitworth | Building & Construction | 3 | 01-25-2012 02:03 PM |
| Attic home theater construction | Cinema Builder | Project Showcase | 23 | 11-19-2009 11:29 PM |
| New Home Construction? | kcrossley2 | Building & Construction | 5 | 01-02-2007 06:52 PM |
| do it yourself home construction | toby72 | Building & Construction | 4 | 06-20-2006 12:32 PM |
