Pipe Fence Painted NOW Flaking~HELP! - Painting - DIY Chatroom Home Improvement Forum
Old 05-30-2008, 10:01 AM   #1
We have a pipe fence that we had painted last summer. Because we had no way of knowing if the existing paint is water base or oil, we treated with TSP prior to painting, then painted with a water base FENCE paint from Tractor Supply. Quite a bit of the fence is already flaking BADLY. Obviously, we want to paint again, but how do we avoid this happening again? Do we 'assume' that we need to use an oil base or ???? TIA
jackieO is offline   Reply With Quote
Old 05-30-2008, 07:23 PM   #2
Rewards Points: 506
TSP is a detergent solution. It will not make water-base paint adhere properly to an oil-base paint substrate. That requires a primer designed for that purpose. (Most folks would use an oil-base bonding primer, but there are water-base formulas for this purpose as well.)
You will need to power-wash and/or scrape and/or sand the failing paint until all the loose stuff is removed, clean, scuff-sand, and then topcoat with bonding primer and then the water-base finish of your choice.
SirWired
sirwired is offline   Reply With Quote
Old 06-01-2008, 08:33 AM   #3
Thank you much for your prompt response and wisdom! I guess we were misinformed the first time around. *sigh* But, at least NOW we have correct information and can remedy the problem and avoid having it happen again. Live and learn. The good thing is that this was only on one long run across the front of the property. Do I just ask for a bonding primer that is being applied to metal? Do you have a preference for an oil or water base primer? Thanks again for your help!!
Painting Pipe fence zubin6220 Painting 13 12-06-2010 10:54 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 03:39 PM
Fence problems-Cement or No Cement WBMill Landscaping & Lawn Care 8 06-17-2007 02:36 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
