Pink Tile - Painting - DIY Chatroom Home Improvement Forum
Old 01-31-2011, 07:26 PM   #1
pink tile
My son has a bathroom with pink tile. I have heard of a product that you can paint on to change the color. Does it really work?
76farmer is offline   Reply With Quote
Old 01-31-2011, 08:00 PM   #2
A Little Of Everything
Rewards Points: 1,356
We've used Zinzer 1-2-3 Primer, and also Kilz Primer on plastic tiles, then top-coated with whatever paint we chose. That has worked very well.
Can't say that it'd work with ceramic or porcelain tiles though. Maybe somebody else knows.
DrHicks is offline   Reply With Quote
Old 02-01-2011, 10:48 AM   #3
Rewards Points: 394
Ceramic tile
For ceramic tile, you need to use an epoxy. That is the only way to obtain adhesion, and provide a surface which can be cleaned. Otherwise, the tile needs to be replaced.
Will22 is offline   Reply With Quote
Old 02-01-2011, 03:13 PM   #4
We are going to test a product on a tub called Homax Tub and Tile. It's a single part white epoxy paint, it can be purchased at your local hardware store. The kit comes complete for prepping and painting. The kit cost around $60 and will paint 1 standard size tub or 2 sinks. 44 to 52 square foot or so they say. (product says works on Fiberglass, Porcelain, Glazed Ceramic Tile and Counter Top Laminate) I will return the results to this post. But yes painting tile is possible.
Shipp's Painting LLC
http://www.paintingkokomoindiana.com
Shipps Painting is offline   Reply With Quote
Old 02-01-2011, 09:06 PM   #5
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
You can't just paint tile with a conventional primer and paint. It is not that easy and will not adhere properly. Especially if the tile are on the floor. You need to scarify/etc the tile first. Midwest chemicals is an on line coatings supplier. They have the proper coatings for tile and they can also instruct you on how to properly prepare the surface first. If you scarify the surface well enough you can then treat the surface as a masonry surface, but you still just can't use any primer or paint off of the shelf.
housepaintingny is offline   Reply With Quote
Old 02-01-2011, 09:09 PM   #6
Rewards Points: 616
I would be curious how that product works? The best product that I know of and have seen work is from midwest chemical, you use an hvlp sprayer and a special uv heat lamp that will actually cure the product in minutes. The kicker is that the heat lamp cost $1,500. So I'm curious as to how well a 60 product works.
Old 02-01-2011, 09:39 PM   #7
Hey Guy if your trying to be disrespectful this is a DIY forum. We test products all the time to try to help customers that can't afford to spend a lot. For what your talking about they might as well replace the tile. Of course there are definitely better more expensive ways to do things but these people are not asking for a contractor with all the equipment to come in and do it, they want to DIY....
LOL on a lighter note I can just see an inexperienced person with an hvlp in their home.
Old 02-01-2011, 10:11 PM   #8
Rewards Points: 616
My name is not guy and if you feel disrespected, because I am curious as to how a product works and I am open minded to learning about a product that I know nothing about then the disrespect that you feel is on you. Any advice that I give on this forum is from my experience. I do know that no matter what product you use on tile if you don't at least etch them first you will not have proper adherance.
Old 02-01-2011, 11:20 PM   #9
I thought you were being sarcastic. My apologies. The product says it comes with everything you need to etch for proper adhesion. This is what I was calling prep.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Pink & Gray Plastic Tile in Bathroom MagicalHome Tiling, ceramics, marble 1 05-10-2010 01:27 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
