Pine Varnish Removal - Painting - DIY Chatroom Home Improvement Forum
Old 08-23-2008, 01:59 PM   #1
Pine varnish removal
Hi, I am trying to remove varnish off of a pine bed. The reason I am removing it is that we are going with a darker stain. I have tried sanding it with 100grit paper but it seems to gum up the sand paper really quick. What is the best way to remove the varnish? Should I use a lower grit or possibly do chemical strip?
Deranged is offline   Reply With Quote
Old 08-23-2008, 02:40 PM   #2
Rewards Points: 2,906
You're sandpaper is gumming up because you're sanding varnish.
You'd be best off to take the bed apart and strip the varnish off of it with a paint stripper that contains methylene chloride as the active ingredient. Paint strippers that call themselves "citrus" strippers or say that the active ingredient is d-Limonene only work OK on latex paints.
Once you strip the varnish off, then you'll have to sand the wood quite a bit to remove the surface layer that has the existing stain in it. Then you can restain the wood and apply a clear coat on top.
Nestor_Kelebay is offline   Reply With Quote
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
