Picnic Table- Paint Or Stain? - Painting - DIY Chatroom Home Improvement Forum
Old 07-31-2012, 08:03 PM   #1
Picnic table- paint or stain?
I just purchased a used picnic table that is a redwood color. It's pretty worn but in good shape otherwise. I'm not sure if it was previously coated with a solid color redwood stain or exterior paint. Is there a way I can tell and would it matter which one I use to refinish?
slickracer is offline   Reply With Quote
Old 08-01-2012, 05:49 AM   #2
Rewards Points: 14,026
Pressure wash it, sand it, rince off then Stain it after a few da ys of letting it dry off. Paint most like will peel, stain will just faid.
Post a picture.
Old 08-01-2012, 06:57 AM   #3
Gymschu's Avatar
Rewards Points: 942
About the easiest way to tell if it was painted is if there is added thickness to the surface from layers of paint. Stain on the other hand, penetrates the surface, rarely peels, and doesn't build up layers of film like paint does. If it's peeling more than likely it's paint. As Joe said, scrape it, clean it, sand it up, clean it off some more & refinish it with stain. It is less likely to peel.
Painting Old House Smokin Gun Painting 36 07-05-2011 01:24 AM
Picnic Table re-painting gone bad? richraquel Painting 5 04-08-2011 02:47 PM
Making paint look like stain Jim McClain Painting 6 12-27-2009 07:50 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
