Perma-white Sheen - Painting - DIY Chatroom Home Improvement Forum
Old 03-22-2012, 03:01 PM   #1
Rewards Points: 264
perma-white sheen
Going to get some Perma-White for the bathroom and have a question about sheen.
I am looking at satin or semi-gloss. How glossy is the semi? When compared to something like SW Pro Classic or BM Super Spec?
7echo is offline   Reply With Quote
Old 03-22-2012, 04:06 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 388
Go with the satin
The Following User Says Thank You to chrisn For This Useful Post:
ltd (03-22-2012)
Old 03-22-2012, 05:55 PM   #3
Mr. Paint's Avatar
Major paint manufacturers all have their paints tested and approved by MPI (Master Painter's Institute). They have standards of systems, product performance and sheens. Sheens are rated on a 60 degree gloss meter. MPI gl5, Semi-Gloss, has a gloss level of 50-55. MPI gl4, eggshell, has a level of 20-25. Approved manufacturers have to fall within these ranges. Zinsser submits their products to MPI..
Mr. Paint is offline   Reply With Quote
Old 03-24-2012, 03:39 PM   #4
ARC Painting's Avatar
I would not use semi-gloss on walls, unless you want the 1950s look.
Satin is much more contemporary, and will be sufficiently durable.
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
Old 03-25-2012, 08:57 AM   #5
Rewards Points: 264
Not the walls...
Sorry for the confusion, this isn't for the walls. I should have been more specific...
I am going to paint the vanity cabinet. The left side of this cabinet is next to the toilet, and pretty close. And this is the 'boys' bathroom(my boy and me) so I need something that wipes and cleans easily
I was thinking Perma-White, but I am open to what you all suggest.
Thanks, and sorry for not letting you guys know exactly what I was doing.
Old 03-25-2012, 02:42 PM   #6
Perma white is forumlated to be impervious to steam, so it will handle the splash, and be washable. I'm not sure about the corrosive factor though, but I don't think it should be an issue. I'd go with the satin as well.
Old 03-25-2012, 04:13 PM   #7
chrisn's Avatar
Rewards Points: 388
If you have not bought any paint yet, I would go with an oil semi gloss for what you described
I am not sure perma white is formulated for wood, it could be,I don't know
Old 03-26-2012, 09:40 AM   #8
Too Short? Cut it Again!
Super spec is Ben Moore's top contractor grade. Good paint but not 100% acrylic. Not sold in quarts.
Which exterior sheen for a white house with black shutters? emory Painting 7 02-11-2012 05:51 PM
Putting color onto white brick or textured walls (need color suggestions!) Eliana Interior Decorating 2 01-18-2012 07:27 PM
glazing white builder grade cabinets - how to get this look? denemante Painting 1 11-04-2011 07:13 AM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 07:54 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
