Perlite Vs Polystyrene Based Popcorn - Painting - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 07:51 PM   #1
Rewards Points: 518
Perlite vs Polystyrene based popcorn
Need to spray popcorn with a hopper. I'm familiar only with polystyrene aggregate. I've seen two local retailers that carry a medium spray texture that says it has perlite instead of polystyrene. Two brands of this that I've seen are very unclear on method of application, and the polystyrene coarse texture has the same unclear instructions(which I know how to spray).
No samples available. Whats this perlite based texture and can it be sprayed like popcorn with a hopper? Does it look alot different or is it a new substitute? I can only assume since perlite is basically sand that it would be very thin and hard to control.
Very confusing. Anyone not paying attention and wanting a medium popcorn ceiling could be buying the wrong stuff as the bags are nearlly identical. Brand names in question are Synko and ProFin.
Synko Snow-Tex - Coarse polystyrene
Synko Ruff-Tex - Medium perlite
Profin doesn't specify a particular "model", just medium or coarse.
I thought there was medium polystyrene out there!!
n0c7 is offline   Reply With Quote
Old 03-07-2009, 10:16 AM   #2
Drywall contractor
Rewards Points: 1,070
Not really familiar with the perlite either. Have you called an actual drywall supply or are you just looking at HD, Lowes, etc.??? I'm pretty sure the perlite would be sprayed with a hopper too. Maybe go to the mfgr.'s web site.......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-18-2009, 06:38 AM   #3
i have perlite in my house on my walls, its not as pronounced as true popcorn texture.
bigburb is offline   Reply With Quote
Latex over alkyd primer TVC15 Painting 15 08-14-2010 11:42 PM
oil vs water poly batwoman Flooring 6 09-30-2008 10:00 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Trends in 2009: POPCORN TEXTURE IS BACK! studiobarb Interior Decorating 11 09-02-2008 06:26 PM
Question about popcorn ceiling J187 Building & Construction 4 06-30-2006 01:33 PM
