Peeling Wall Paint - Painting - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 11:09 PM   #1
peeling wall paint
we have a spot on a wall about 1 foot square that is peeling. Is it necessary to remove paint from the whole wall before repainting or can I just repair that one spot first? It is sand textured paint.
rubydee is offline   Reply With Quote
Old 01-23-2012, 02:00 AM   #2
A Little Of Everything
Rewards Points: 1,356
No, it's not necessary. But you'll definitely need to figure out why that small area is peeling, or you'll have the same problem. Determining why it's peeling will also dictate what primer you use before painting.
DrHicks is offline   Reply With Quote
Old 01-23-2012, 05:20 AM   #3
Ruby, there could be a few reasons why you have a problem. Different causes of failure have different appearances. Can you take a pic to post? How old is the paint that is failing? Is it a new/fresh paint job? Also, it helps to know what's behind the wall where the failure is occuring. Is it an exterior wall where moisture could be entering? Is there a pipe or duct that could be causing an issue? I had a customer who was having water staining on a second floor ceiling, less than one year old house. Had the roofer check the roof, no problems. Turns out the duct installers left a section of of AC duct uninsulated in the attic that was condensing moisture and dripping onto the insulation/ceiling. You never know why a particular spot will fail. If it was a paint failure, it wouldn't be localized to one spot.
The Following User Says Thank You to jsheridan For This Useful Post:
Gymschu (01-23-2012)
Old 01-23-2012, 09:18 AM   #4
Gymschu's Avatar
Rewards Points: 168
............and, once you find the source of the problem, you will find that patching textured (sand textured) walls is much easier than patching a regular wall. Hopefully, you still have some of the sand texture paint leftover.
Old 01-23-2012, 10:04 PM   #5
It's important to determine the cause of the paint failure considering it is localized on the wall.
Recently we were called back to a new construction for a paint failure. Upon inspection of the paint failure it was clear to me it was a moisture issue from a plug outlet above. Once we cut out the drywall it was clear there was a leak behind the vapor barrier, which was entering from a small hole in the vapor barrier around the plug outlet. Eventually after 1 1/2 hours outside with our pressure washer and a man in the attic to locate the leak at the chimney flashing along the roof.
Home owner's only regret was not calling us back as soon as they discovered the failing paint.
CB Painters is offline   Reply With Quote
Old 01-23-2012, 10:16 PM   #6
Rewards Points: 12,790
Where is it on the wall? Top bottom, middle?
Old 01-23-2012, 10:25 PM   #7
It's amazing that the point of entry and the place it appears can be so distant. I've seen some crazy sheet over the years. It sometimes takes ingenuity and thinking outside the box to figure out where water is coming from. But, when you find it, you're a hero!
Old 01-24-2012, 10:17 AM   #8
HOs took it as an "educational experience" that a pro's knowledge and experience are invaluable. I was happy they called us back and trusted us to take care of it for them rather then going through the hassle of getting that particular developer to take responsibility. Which was the case at that time.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
peeling interior paint packer_rich Painting 4 12-30-2011 10:24 PM
Ceiling Paint White versus Wall Paint White David Riley Drywall & Plaster 1 01-13-2011 10:16 AM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Blue tape peeling away the old wall paint drlsubaru Painting 9 05-13-2009 10:58 AM
