Peeling Sheetrock While Removing Wallpaper - Painting - DIY Chatroom Home Improvement Forum
Old 07-21-2012, 11:05 AM   #1
Red face
peeling sheetrock while removing wallpaper
I am removing wallpaper and some of the outer cover of the sheetrock has come off.
joe pippen is offline   Reply With Quote
Old 07-21-2012, 12:21 PM   #2
Too Short? Cut it Again!
When you get everything off, wash the walls down to get as much wallpaper paste residue off as possible. Then apply a coat of GARDZ. Gardz will seal the peeled areas and give you a uniform and bondable surface again. Then skim coat with drywall compound to fill in and level the wall. Prime again and paint with two coats of finish. You can use a good bonding primer over the skim coat and do not need Gardz for that. Zinsser 123 or Benjamin Moore Fresh Start would be possibilities.
Old 07-21-2012, 01:21 PM   #3
Gymschu's Avatar
Rewards Points: 464
As Sdsester says.......also, don't be shy about using the SEARCH function on this great Website........there are literally hundreds of threads on this very topic.
The Following User Says Thank You to Gymschu For This Useful Post:
user1007 (07-21-2012)
Old 07-21-2012, 05:27 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
at least
Old 07-24-2012, 04:35 PM   #5
Rewards Points: 39
+1 on the above...to a tee. Oh, and it sucks. My kitchen was half completely peeling wallpaper that would come off by simply pulling it off and half "welded" wallpaper that came off only with the drywall attached. And yes, that was with wallpaper remover and the holes scored into it.
Plump is offline   Reply With Quote
Old 07-24-2012, 05:50 PM   #6
chrisn's Avatar
Rewards Points: 228
all due to improper application
and it is soooooooo easy to do it right
Repairs after removing wallpaper pwgsx Drywall & Plaster 7 04-06-2012 06:39 PM
Skim Coating wall After removing wallpaper stevenson66 Painting 6 11-08-2010 08:35 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 02:32 AM
Removing Wallpaper fcamargo6thave Painting 17 04-27-2009 03:59 AM
Removing wallpaper and repairing plaster walls Boroco General DIY Discussions 3 03-27-2009 02:27 PM
