-   -   peeling sheetrock while removing wallpaper (http://www.diychatroom.com/f4/peeling-sheetrock-while-removing-wallpaper-151041/)
joe pippen 07-21-2012 11:05 AM
I am removing wallpaper and some of the outer cover of the sheetrock has come off.
user1007 07-21-2012 12:21 PM
When you get everything off, wash the walls down to get as much wallpaper paste residue off as possible. Then apply a coat of GARDZ. Gardz will seal the peeled areas and give you a uniform and bondable surface again. Then skim coat with drywall compound to fill in and level the wall. Prime again and paint with two coats of finish. You can use a good bonding primer over the skim coat and do not need Gardz for that. Zinsser 123 or Benjamin Moore Fresh Start would be possibilities.
Gymschu 07-21-2012 01:21 PM
As Sdsester says.......also, don't be shy about using the SEARCH function on this great Website........there are literally hundreds of threads on this very topic.
chrisn 07-21-2012 05:27 PM
at least:thumbsup:
Plump 07-24-2012 04:35 PM
+1 on the above...to a tee. Oh, and it sucks. My kitchen was half completely peeling wallpaper that would come off by simply pulling it off and half "welded" wallpaper that came off only with the drywall attached. And yes, that was with wallpaper remover and the holes scored into it.
chrisn 07-24-2012 05:50 PM
all due to improper application:furious:
and it is soooooooo easy to do it right:censored:
