Peeling Semi-gloss On Bookshelves - Help! - Painting - DIY Chatroom Home Improvement Forum
Old 09-20-2009, 11:42 AM   #1
Question
Peeling semi-gloss on bookshelves - help!
My husband did a good job painting the interior of our new home. Unfortunately, when it came to our built-in bookshelves, I don't think he primed over the other semi-gloss when painting with the new semi-gloss white paint. When we put the books in, the paint is peeling off in sheets. How can we fix this? Do we have to strip? :P Any way to avoid sanding? Any and all advice would be much appreciated.
hillary is offline   Reply With Quote
Old 09-20-2009, 02:18 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Paint does need a month to fully cure, but shouldn't peel off that easy. Take off the peeling layer. Leave the paint underneath if it is in good shape. If it is latex nderneath, give it a good scuff sanding with some 80-100 grit sand paper, prime with some good quality latex primer like Zinsser 123 and top coat with a quality paint. If the paint underneath is oil, you really need to give it a coat of oil based primer like Zinsser Cover Stain to make the transition to latex or just top coat with oil.
Old 09-20-2009, 07:43 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Sounds like a latex over oil job to me, follow Mathew's advise.
Old 10-17-2009, 11:10 AM   #4
Thank you very much for the advice. I've managed to scrape the latex paint off (mostly) -still working on the detailed areas. What do you suggest for the areas where I scraped down to the wood (not many, just small). Will the primer be sufficient?
Old 10-17-2009, 11:10 AM   #5
PS How can I tell if the original paint was latex or oil?
Old 10-18-2009, 06:32 AM   #6
chrisn's Avatar
Rewards Points: 228
Rub it with denatures alcohol, goof off or nail polish remover, if it comes off it is latex, if not,it is oil.
Tags
peeling paint , semi gloss
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
Semi gloss on Semi gloss mattpricemn Plumbing 1 08-24-2008 04:19 PM
Removal of peeling semi gloss paint from ceiling L Lacey Painting 2 08-15-2008 05:15 PM
semi gloss sheen problems Pawl Painting 5 03-15-2008 11:29 PM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 04:47 PM
