Peeling Paint In Window Frame - Painting - DIY Chatroom Home Improvement Forum
Old 09-06-2008, 02:02 PM   #1
Rewards Points: 12
Peeling Paint in Window frame
I have a window that is recessed about 6 inches in a frame and there is paint peeling off the inside top portion of this frame before the window starts.
I am starting to scrape the paint off of this section and there seems to be a white powdery film underneath - if I run my finger on it I have a white powder marks on my finger. Any idea what this is?
What is th best prep to re-paint this - scrape off all paint, fill in any spots with compound, sand, paint? Also, when I scrape the paint off, I also took off some old caulk in the corners - what is best way to re-caulk these areas and what kind of caulk should I use?
Thanks!!
duffeymt is offline   Reply With Quote
Old 09-06-2008, 04:53 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Interior?
Dust is probably old primer/paint
Best prep:
Scrape, sand, prime
Then If Needed:fill/repair, sand, dust, prime (fill/repair areas)
Then: paint
slickshift is offline   Reply With Quote
Old 09-06-2008, 05:02 PM   #3
slickshift's Avatar
...oops, caulk after priming, before painting
Any good quality Siliconized (NOT SILICONE) Paintable Acrylic Caulk should be fine
Ben Moore or Sherwin Williams 35/45 year stuff, Phenoseal or Alex
I like the quick dry Lightening Bolt myself
Old 09-07-2008, 10:52 PM   #4
Rewards Points: 2,906
I'd be concerned that the root of the problem is that the flashing above the window is leaking, allowing water to drip onto the top of that window frame. That is getting the wooden window frame wet, causing the paint to peel off the underside of it.
Maybe see if there's anything funny going on above the window on the outside of the wall.
Nestor_Kelebay is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 05:29 PM
