Peeling Paint Problem - Painting - DIY Chatroom Home Improvement Forum
Old 08-28-2013, 07:41 PM   #1
gloriousglenn's Avatar
Rewards Points: 31
Hi all,
I am having a problem with my kids playroom!
We painted the walls recently (green), straight over the top of the old paint, and it is now peeling!!
The previous paint was fine! We didn't prime, we didn't rough it up, or anything like that. We are pretty sure (99%) it's latex on top of latex, but not 100% sure. So I suppose this is a two part question:
1) What is the easiest way to get rid of the current peeling paint? Hand peeling is obviously very time consuming.
2) How do we stop it from happening again, when we go to repaint?!
A guy at Home Depot said the only option is to rip down the drywall and start again, but that sounds a bit extreme....or so I'm hoping anyway!!
Thanks all
Glenn
gloriousglenn is offline   Reply With Quote
Old 08-28-2013, 08:04 PM   #2
Rewards Points: 6,034
The first thing you need to do is get away from Home Depot, the advice he gave you is not just bad it's downright stupid. Remove the loose paint, go around the edges with PEEL STOP triple thick, as per the directions. Then go over the whole wall with a bonding primer then paint with the new paint you got at a real paint store.
The Following User Says Thank You to ToolSeeker For This Useful Post:
gloriousglenn (08-29-2013)
Old 08-28-2013, 09:00 PM   #3
Rewards Points: 4,796
Taking down drywall is definitely too extreme, because the original paint was doing fine. Therefore the worst case scenario would be sanding off all the new green paint. That would most likely solve whatever problem existed with the surface of the old paint that kept the new paint from sticking. I assume the new paint was fresh and applied correctly. Washing the walls with a deglossing cleaner is never a bad idea if the original paint was not flat, but even if it was the cleaner part will still help.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Old 08-29-2013, 06:35 AM   #4
Rewards Points: 31
Hey guys,
Thanks for the advice. I'm pretty pleased that the drywall doesn't have to come down!! I've only just finished putting up a new ceiling because of Stucco!!
Originally Posted by ToolSeeker View Post
...go around the edges with PEEL STOP triple thick, as per the directions...
Would I not potentially still have a problem with the rest of the green paint peeling away?
Originally Posted by jeffnc View Post
...Therefore the worst case scenario would be sanding off all the new green paint...
The first job then, would be to get rid of the green paint, and 'rough up' the paint underneath. Can I assume that the more coarse sandpaper the better?
...I assume the new paint was fresh and applied correctly...
Yes. We thought we did it all correctly! In hindsight I would have roughed up the old stuff and primed it first!
...Washing the walls with a deglossing cleaner is never a bad idea if the original paint was not flat, but even if it was the cleaner part will still help....
Deglossing cleaner now on the shopping list!
Thanks again guys.
Glenn
Old 08-29-2013, 06:53 AM   #5
Well, to a point, of course. 40 is too coarse. 150 is too fine. One problem is that the best grit for paint removal is coarser than the best grit for just scuffing a paint surface.
Old 08-29-2013, 06:29 PM   #6
ltd
Rewards Points: 536
with out seeing it up close and personal, I would keep striping wit water or krud cutter . use green pads or better yet stripping pads and medium grit 3 m type sand paper and wet sand it .ok now prime walls with cover stain let dry .and paint away
ltd is offline   Reply With Quote
Old 08-29-2013, 08:11 PM   #7
The only paint you have to remove is what is loose Peel stop will keep it from loose along the edges.
Old 08-30-2013, 03:18 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
Hey guys,
Thanks again guys.
Glenn
If you are sanding, there is no need for this, in fact there is no need for this in the first place
Old 08-30-2013, 06:21 AM   #9
The thing about deglossers or liquid sandpaper or TSP type products is if you don't get them all off the wall they can cause more problems than they can fix.
cdaniels (08-30-2013)
Old 08-30-2013, 06:44 AM   #10
Gymschu's Avatar
Rewards Points: 1,022
I say leave it like it is. It's kinda cool. Looks like a map of Lower Slobodia or some other far off land.
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
gloriousglenn (10-21-2013), Will22 (08-30-2013)
Old 08-30-2013, 08:08 AM   #11
Rewards Points: 31
The only thing I'm worried about this is the remaining green paint. I can rub my fingernail anywhere on this paint and it will come off, as it hasn't adhered properly anywhere. if I then paint over the top of this, wouldn't it still potentially be able to peel?
Thanks for that. It's interesting to see how there is obviously so many ways to skin a cat.
If I thought I could convince the wife of this, I would!
Old 08-30-2013, 08:33 AM   #12
Hmm, looks just like one of my rooms that I'm peeling off big sheets. Other areas I can rub my finger on to get a peel started.
remove, prime, paint
toastandjam is offline   Reply With Quote
Old 08-30-2013, 09:43 AM   #13
If it is adhering that bad you have no choice but to sand it all off prime, and repaint.
Old 08-30-2013, 04:50 PM   #14
chrisn's Avatar
Rewards Points: 612
I agree, the green must go
Old 08-30-2013, 05:08 PM   #15
It depends on the type of cleaner. There are now non-TSP cleaners and deglossers that are designed for not having to rinse them off. I've had good success with Klean-Strip Easy Liquid Sander Deglosser. No sanding (assuming a smooth surface to begin with) and no rinsing before painting.
How do I fix peeling paint? papageek Painting 3 08-01-2012 02:05 PM
recurrent peeling paint on interior walls Krista2 Painting 14 09-10-2011 03:17 PM
peeling paint on plaster paqqj Painting 1 04-12-2011 03:29 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
