Peeling Paint On Exterior Wall - Painting - DIY Chatroom Home Improvement Forum
Old 05-22-2012, 05:56 AM   #1
Peeling Paint on exterior wall
HI,
Im looking for some much needed advice on the problem I have with my exterior wall. As you can see from the images below the paint is peeling very badly. I painted this wall in May 2010. Everything was fine up until December when the peeling started. Since then it hasnt stopped. It is a real eye sore looking out my living room window.
How can I remove the paint left on the wall? When re-applying paint what preperations will I make? Again any advice would be much appreciated!
Peeling Paint on exterior wall-img_1477.jpg   Peeling Paint on exterior wall-img_1478.jpg   Peeling Paint on exterior wall-img_1479.jpg
phillers is offline   Reply With Quote
Old 05-22-2012, 06:49 AM   #2
Rewards Points: 13,978
Ok what materail is it?
One picture looks like aluminum and the rest look like it's a concrete slab.
Old 05-22-2012, 07:21 AM   #3
Hi Joe,
Material is concrete. Wall is built with cavity bloack and then a plastered finish applied.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
recurrent peeling paint on interior walls Krista2 Painting 14 09-10-2011 03:17 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
