Peeling Paint On Concrete Floor - Painting - DIY Chatroom Home Improvement Forum
Old 06-11-2009, 02:35 PM   #1
I recently bought a home that has an unfinished basement with a concrete floor. The floor has been painted but was apparently not prepared properly and the paint sticks to whatever is placed on it. I'd like to remove the old paint, properly prepare the concrete, and repaint.
I would appreciate any suggustions as to how to remove the old paint.
Thank you,
Duke76
Duke76 is offline   Reply With Quote
Old 06-11-2009, 02:46 PM   #2
Rewards Points: 506
Stripper, if you can stand the fumes, or maybe a pressure washer if it has a drain?
sirwired is offline   Reply With Quote
Old 06-11-2009, 02:54 PM   #3
Thanks for the reply. There is no floor drain for a pressure washer. I have a marine aquarium located nearby, in a finished area of the basement so the fumes from stripper would be a problem. May be the only solution though.
Old 06-11-2009, 03:33 PM   #4
yummy mummy's Avatar
Rewards Points: 1,016
I finished doing just that. Removing paint from concrete basement.
I also did not want to use a stripper with fumes so I was able to find a product call safe strip that has no fumes, enviro friendly, water based that works really well.
It is pricey but worth it to me.
yummy mummy is offline   Reply With Quote
Old 06-11-2009, 03:34 PM   #5
NAV
you are going to have to scrape it up or use a floor buffer with a sanding pad. sounds like most will come up easily.
the problem may not be a prep issue. you said it's a basement. the floor is below grade so hydrostatic pressure will cause moisture to come up through the concrete. if that is the case you will not be able to coat the floor with any type of paint (possibly a slurry coat but that runs close to $20 per square foot for jobs over 10,000 sf)
you are better off just using an indoor outdoor carpet and gluing it to the floor (bet you can do it for under $6 per sf). leave the existing paint it will help when you go to replace the carpet after a flood.
there are other options that involve moisture barriers and sub-floors but you are getting up to the $20 sf range again.
NAV is offline   Reply With Quote
Old 06-11-2009, 07:20 PM   #6
Tired, Cold, and Damp
slickshift's Avatar
Rent a floor grinder from your local rent-all shop
Removing all the old coating and applying a new proper one is the solution
slickshift is offline   Reply With Quote
Old 06-12-2009, 06:56 AM   #7
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
If you want to strip it look into Peel Away 1. It's a thick paste you put down and press a paper into it. Let it go overnight and you should be able to peel back the paper with a putty knife and take all the paint with it. This product is zero VOC. No fumes. It'll still burn your hands though if you don't wear gloves. It does require an acid neutralizer afterwards though.
poppameth is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
getting rid of carpet > concrete floor > polish or stain? johnlvs2run Flooring 24 11-23-2010 11:31 PM
How to cut a hole in a concrete floor slab tomseeley General DIY Discussions 7 06-10-2009 03:32 PM
concrete paint removal before tile installation SR996 Flooring 1 03-21-2009 08:31 PM
Epoxy Paint on Previously Painted Concrete Floor goodkarma Painting 6 07-10-2008 02:04 PM
