Peeling Paint On Bathroom Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 04-16-2012, 03:38 PM   #1
Peeling paint on bathroom ceiling
Following a previously repaired damp issue, I repaired a bathroom ceiling that was suffering from flaky paint.
These are the steps I took:
I scrapped away all loose paint
sanded the ceiling smooth
damp wiped the area
sealed with pva
applied plaster skim to areas that needed to be made smooth
once dried applied a further coat of pva
once this had dried, the following day, I applied 2 coats of damp sealer (solvent based)
The following day I applied an Anti- Condensation paint (International brand).
6-7 months have now passed and the ceiling paint is starting to flake again.
Have I done anything wrong and how should I go about repairing this now to ensure this does not happen again? The bathroom ceiling is drywall/plasterboard.
I would welcome any advise - thank you
NadiaHD is offline   Reply With Quote
Old 04-16-2012, 04:56 PM   #2
Mr. Paint's Avatar
Which layer is the flaking peeling to? What is the brand of the solvent-based damp sealer? What is the product number of the Anti-Condensation paint that was used? Which "plaster skim" did you use? There is a reason for loss of adhesion. Answers to the questions help us in determining a probable cause.
Mr. Paint is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Tar bleeding through paint on bathroom ceiling dwoloz Painting 5 08-15-2010 09:10 PM
Bubbling paint on ceiling caused by damp bathroom floor garv19 General DIY Discussions 4 04-10-2010 08:38 AM
Bathroom Ceiling with radiant heat Chatterbox Painting 6 10-13-2009 04:16 AM
Bathroom ceiling primer and the paper peeling off beedee Painting 10 09-05-2009 01:35 PM
