Peeling Paint - Painting - DIY Chatroom Home Improvement Forum
Old 04-05-2010, 06:59 PM   #1
Peeling Paint
The ceiling in my bathroom has peeling paint. Unfortunately it had peeled off in large patched and not all the way. This is a house built in the 1950's and the walls are plaster. The paint has peeled down to the plaster. Someone has repainted but you can still see where the paint was peeled off. How can I even/smooth the surface so this doesn't show when I repaint. Thanks.
Davep is offline   Reply With Quote
Old 04-06-2010, 08:25 AM   #2
ccarlisle's Avatar
Well, one thing you should do regardless of the current state of your ceiling is to use the proper paint. Sounds simple but most don't know enough not to use PVA-based paints - that's the type of resin used...PVA resins are permeable and tend to swelll with moisture so knowing not to use them in a bathroom is one key I can contribute.
That alone pretty well rules out any big box store paint.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 04-08-2010, 09:20 PM   #3
Heritage Restoration
Same reason to never use everyday White Glue outside or in a bathroom. It absorbs the moisture again very easily.
Basic rule of thumb. Avoid Box Stores.
lol
(i'm actually about 90% serious)
Skuce is offline   Reply With Quote
Old 04-08-2010, 09:29 PM   #4
hire a professional.....
JP in Mich is offline   Reply With Quote
Old 04-09-2010, 09:17 AM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
Joint compund. 3 skim coats wil do it. Sand prime and paint. You can pick up a can of spray Bin or Cover Stain so you on'thave to use a whole setup to prime with.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
