Old 12-28-2006, 03:28 PM   #1
Peeling Paint
We just put up new wall and primed and paint them. The primer (Kilz Premium latex & Sherman Williams Pro Block Latex) and paint are peeling off the joint compound and there is a dusty film on the back of the paint. We washed the walls down with a damp cloth (water) and were not dusty or gritty before we painted. The paint is peeling off in sheets. Is there a way to seal the joint compound? Is there something we are doing wrong? Please help!!!!
lawlor is offline   Reply With Quote
Old 12-28-2006, 09:36 PM   #2
Pro Painter
Peeling Paint
Sounds like the joint compound was dry on the surface and moist underneath. Just let it dry thoroughly.
Another possibility is that the first coat was too heavy. Without seeing it, there's no way to know for sure. Both primers you mentioned are good primers, but you might want to thin them down a little or make sure you apply thinner coats.
the primer IS the sealer. I'm pretty sure if you just consider the two possibilities above, you'll be fine next time around.
joewho is offline   Reply With Quote
Old 12-30-2006, 03:28 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Peeling Paint
How long was the j/c allowed to dry?
How long after the 'washing" did the walls get to dry?
What kind of j/c was used?
A dusty film on the back of a peal generally indicates dust contamination of the surface
It could be that it was still damp also
The latex Kilz has a high failure rate
If it was the Kilz-ed parts that failed, I wouldn't be surpised
For future ref, I'd not use the latex Kilz, and not clean with a damp rag
A dry type Swiffer hasn't ever let me down for prep
The one on a stick is great and makes quick work of dusting the wall
slickshift is offline   Reply With Quote
More On This Topic
Knowing the properties and uses of paints will save a great deal of time, money and work over time. The right paint choice will help the finish last its longest and look its best. Read More »
Cleaning the blinds can be very easy. Start by dusting, you can use the dusting attachment on your vacuum cleaner and that will help suck all the vacuum out, I mean suck all the dust out. Go on each side by vacuuming, turn the blinds around, leave them... Read More »
Tiled counter tops are very classy looking until the grout joints get stained or begin to loosen. You can save the expense of replacing the counter with just a little work. Re-grout the tile on your counter by following the steps and tips below. Read More »
Latex is one of the most versatile paints available. One vareity is vinyl based, which dries quickly and has a priming feature. Acrylic-based latex paints provide the toughest finish for durability and washing. These also have a drying time of just one... Read More »
While we sleep, our bodies dispel millions of dead skin cells every night. Unfortunately, dust mites, which are microscopic organisms that live and thrive in dust, feed off those dead skin cells and propagate in our mattresses. By taking a few... Read More »
Paint peeling off Bathroom Ceiling!!! armen30 Painting 16 02-18-2010 12:43 PM
how to remove peeling semi-gloss paint amydiy Painting 5 04-09-2007 10:06 PM
Peeling paint Lisalovespainting Painting 7 02-17-2007 08:52 AM
Smoothing a door with peeling paint Tmb9862 Painting 4 01-31-2007 03:38 PM
Latex paint peeling...HELP coorsabee Painting 4 09-11-2006 10:16 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
