-   -   Peeling Paint (http://www.diychatroom.com/f4/peeling-paint-5583/)
lawlor 12-28-2006 02:28 PM
Peeling Paint
We just put up new wall and primed and paint them. The primer (Kilz Premium latex & Sherman Williams Pro Block Latex) and paint are peeling off the joint compound and there is a dusty film on the back of the paint. We washed the walls down with a damp cloth (water) and were not dusty or gritty before we painted. The paint is peeling off in sheets. Is there a way to seal the joint compound? Is there something we are doing wrong? Please help!!!!
joewho 12-28-2006 08:36 PM
Sounds like the joint compound was dry on the surface and moist underneath. Just let it dry thoroughly.
Another possibility is that the first coat was too heavy. Without seeing it, there's no way to know for sure. Both primers you mentioned are good primers, but you might want to thin them down a little or make sure you apply thinner coats.
the primer IS the sealer. I'm pretty sure if you just consider the two possibilities above, you'll be fine next time around.
slickshift 12-30-2006 02:28 PM
How long was the j/c allowed to dry?
How long after the 'washing" did the walls get to dry?
What kind of j/c was used?
A dusty film on the back of a peal generally indicates dust contamination of the surface
It could be that it was still damp also
The latex Kilz has a high failure rate
If it was the Kilz-ed parts that failed, I wouldn't be surpised
For future ref, I'd not use the latex Kilz, and not clean with a damp rag
A dry type Swiffer hasn't ever let me down for prep
The one on a stick is great and makes quick work of dusting the wall
