Peeling Paint - Painting - DIY Chatroom Home Improvement Forum
Old 01-14-2008, 09:38 PM   #1
peeling paint
After removing the baseboards and chair rails from our dining room, some of the paint peeled. We are pretty sure it's all latex paint (water-based) and there is no oil-based paint base (the house was built in 2003). We are going to prime and repaint all walls. What should we do to prep the walls with peeling paint? Seems like we should peel all peeling paint off, but it is also pulling some of the drywall paper off with it.
thanks,
Chris
stallinc is offline   Reply With Quote
Old 01-14-2008, 10:11 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Peel/scrape/sand any/all loosely adhering and/or pealing paint
If the drywall "paper" has ripped, treat those areas with a coat of Zinsser's Gardz before patching with joint compound
Sand to feather any repair areas
Sand (and dust) walls and prime with a quality latex (acrylic) primer
* excessive pealing may require a problem solving primer, just a few areas- shouldn't need it
slickshift is offline   Reply With Quote
Old 01-17-2008, 06:37 AM   #3
Great, thanks!
Old 01-17-2008, 09:53 AM   #4
Rewards Points: 506
Sounds like the builder just didn't prime to begin with. You may want to consider Gardz on everything; it might help "lock things down" for what you can't scrape.
Then sand, vac, tack, prime with quality paint-store primer, and top-coat with quality paint.
SirWired
sirwired is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Exterior trim paint is peeling, wood is rotting! firsthomenewb Painting 10 05-15-2008 06:04 PM
how to remove peeling semi-gloss paint amydiy Painting 5 04-09-2007 10:06 PM
Peeling paint Lisalovespainting Painting 7 02-17-2007 08:52 AM
Peeling Paint lawlor Painting 2 12-30-2006 03:28 PM
