Old 12-17-2011, 03:17 PM   #1
Peeling Paint
I've got paint peeling on the door frame in one of my rooms. It's peeling on about 40% of the frame. No other damage is noticeable. Any idea on why this happens? Finally, what is the best way to remedy the situation?
Steve
gerardswork is offline   Reply With Quote
Old 12-17-2011, 05:25 PM   #2
Gymschu's Avatar
Peeling Paint
Possibly woodwork that had polyurethane on it and was painted over with paint. They likely skipped the step of applying a bonding primer. Scrape, prime with a bonding primer, and repaint.
Old 12-17-2011, 05:27 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Peeling Paint
New paint? New board? What paint? What was there already?
Hard to answer questions without knowing anything
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-17-2011, 06:03 PM   #4
Peeling Paint
20 year old house...I've peeled back some of the peeling paint and have determined its the first coat.interesting because it's only in one room...no water damage that I know of...I guess I'm more interested in knowing how to fix it than the history
Old 12-17-2011, 06:08 PM   #5
Disabled wood vet
titanoman's Avatar
Peeling Paint
They probably ran short on new trim and reused something that had varnish or something on it.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-17-2011, 06:15 PM   #6
Peeling Paint
No primer or someone painted over oil based paint is what it looks like.
If there was no primer then all the paint will come off with nothing left on the wood.
Old 12-17-2011, 06:47 PM   #7
Gymschu's Avatar
Peeling Paint
In cases like this I like to use a RAZOR blade scraper. You can remove nearly all the peeling paint with it........it takes more time, but you can get nice clean edges without breaking out the sander.......sometimes.
Old 12-19-2011, 02:52 PM   #8
Peeling Paint
It looks like latex paint over an old alkyd, which has become very brittle.
Will22 is offline   Reply With Quote
Old 12-19-2011, 11:37 PM   #9
Matthewt1970's Avatar
Peeling Paint
That could also be a problem with the wood. Is the wood sound underneath?
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 12-19-2011, 11:39 PM   #10
Peeling Paint
Not sure on the type of wood. I thought it could have been moisture, but its on the other side of the room as well...the wood looks like its in great condition. Not sure on the type of wood.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
recurrent peeling paint on interior walls Krista2 Painting 14 09-10-2011 04:17 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
