-   -   Peeling Paint (http://www.diychatroom.com/f4/peeling-paint-126874/)
gerardswork 12-17-2011 03:17 PM
Peeling Paint
2 Attachment(s)
I've got paint peeling on the door frame in one of my rooms. It's peeling on about 40% of the frame. No other damage is noticeable. Any idea on why this happens? Finally, what is the best way to remedy the situation?
Steve
Gymschu 12-17-2011 05:25 PM
Possibly woodwork that had polyurethane on it and was painted over with paint. They likely skipped the step of applying a bonding primer. Scrape, prime with a bonding primer, and repaint.
Brushjockey 12-17-2011 05:27 PM
New paint? New board? What paint? What was there already?
Hard to answer questions without knowing anything
gerardswork 12-17-2011 06:03 PM
20 year old house...I've peeled back some of the peeling paint and have determined its the first coat.interesting because it's only in one room...no water damage that I know of...I guess I'm more interested in knowing how to fix it than the history
titanoman 12-17-2011 06:08 PM
They probably ran short on new trim and reused something that had varnish or something on it.
Sent from a Samsung Galaxy S2
joecaption 12-17-2011 06:15 PM
No primer or someone painted over oil based paint is what it looks like.
If there was no primer then all the paint will come off with nothing left on the wood.
Gymschu 12-17-2011 06:47 PM
In cases like this I like to use a RAZOR blade scraper. You can remove nearly all the peeling paint with it........it takes more time, but you can get nice clean edges without breaking out the sander.......sometimes.
Will22 12-19-2011 02:52 PM
It looks like latex paint over an old alkyd, which has become very brittle.
Matthewt1970 12-19-2011 11:37 PM
That could also be a problem with the wood. Is the wood sound underneath?
gerardswork 12-19-2011 11:39 PM
Not sure on the type of wood. I thought it could have been moisture, but its on the other side of the room as well...the wood looks like its in great condition. Not sure on the type of wood.
