Peeling Kitchen Cabinets - Painting - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 07:30 PM   #1
peeling kitchen cabinets
We are remodeling an older home and th ekitchen cabinet paint is peeling in large sections. It appears the previous owners may have painted latex over enamel and now there are large bubbles wherfe whole sections of paint can be pulled off. Other areas where it is not peeling and adheres well. What's the best way to prepare the cabinets for new paint?
Shipper is offline   Reply With Quote
Old 02-27-2011, 10:48 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
I would use oil primer to be safe.
Old 02-28-2011, 03:21 AM   #3
It sounds more like the current top coat is not bonded to the previous coat. Sanding is the most neglected, and most important, step in the prep phase. What are they peeling down to, another coat of paint or original surface? Ideally, you want to get the whole surface down to the same level uniformly, which means stripping the remaining paint. It should scrape off fairly easily with a thin spackle blade that will get underneath it, carefully. A heat gun, used carefully, would likely take the remaining stubborn top coat off without disturbing the previous coat. Sanding it will cause the latex edges to keep lifting. If you disturb the previous coats you'll have to take it down completely or get involved in patching. You don't want patches on kitchen cabinets. Once it's level, give the surface a good sanding with 150 grit, wash them with water and tri-sodium phosphate, rinse, apply a good bonding primer, then apply the finish of your choice. BTW, an enamel can be latex or oil. Good Luck.
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 06:14 PM
Painting Kitchen Cabinets, Back wall NewlywedKristin Interior Decorating 12 03-18-2010 10:23 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
