Peeling/flaking Paint Over Stain - Painting - DIY Chatroom Home Improvement Forum
Old 10-04-2009, 09:31 PM   #1
Question
peeling/flaking paint over stain
been in my house 6yrs looks like homeowner painted over all the trimm and doors wich were stained with latex paint, now all is chipping and peeling. I'm assuming they didnt sand and primer prior to painting. how do i fix? I repainted kitchen and trim so I scraped sanded and touched up with filler to even out were the paint chipped off, then primered and painted was this ok? have a better suggestion?
rperezwyd is offline   Reply With Quote
Old 10-04-2009, 10:57 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
That's the way to do it. Just make sure you use a good primer and top coat.
Old 10-05-2009, 06:00 AM   #3
i have a couple of primers laying around it is an exterior oil based primer valspar and bullsy interior which do u recomend
Old 10-05-2009, 09:35 AM   #4
Too Short? Cut it Again!
Given that you may have an oil-based varnish or poly over the stained trim, my first choice would be a solvent based alkyd primer because it is a great equalizer. Second choice would be a high quality bonding latex primer. I personally would not use either the Valspar or the Bullseye. I would use something like Benjamin Moore's Fresh Start (either alkyd or latex) primers. MAB's Superbond Primer is good. Sherwin Williams (especially now that MAB is a SW company) will have something equivalent to these.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
