Originally Posted by DIYknievel
Greetings, I have painted a bathroom ceiling that has a swirl-pattern finish using Ben Moore ceiling white. The paint is now cracking and peeling off over the shower and is spreading to the rest of the room. The paint is good. The peeling must be a result of someting I did or didn't do. I also get the feeling I have to scrape the entire ceiling and start over.
Generally, If you scrape the paint off a pattern like that, you may end up damaging the swirl pattern and having to repair that too.
The reason why the ceiling is peeling like that is due to the high amount of moisture from the shower steam.
Do you have an exhaust fan/vent in the bathroom?
You might consider using a mildew resistant primer and paint or a mildecide additive. Do not use oil paint, if the previous layers of paint were latex, or it too will crack.
If you find that you choose to, or need to, repair the swirl pattern, this can be done using a stiff plaster's brush or wide firm bristled paint brush, dependant on the exact pattern style.
If it is a sand swirl texture, you can purchase sanded texture at just about any BIG HOME improvement type stores...
1. The ceiling in the other bathroom and the kitchen ceiling are the same swirl pattern and they need to be painted. What should I use to paint over the swirl pattern.
Basic latex paint will do it.
2. The rest of the ceilings in the house are different. They are a stucco-type finish. The house was built in 1982 in central MA. Is there a reason the builder did not use the stucco finish on the ceilings in the kitchen and baths?
Couldn't tell you. Could be something as simple as: two different sub contractors did the work. One did swirls because he wasn't good at doing the other pattern, or vice versa....There really isn't any cost difference betweeen the two styles, just builder or client preference.
3......how do I get the paint and applicator to create this stucco-type ceiling?
I believe what you are referring to is what we call a 'skip-trowel' pattern, rather than 'stucco'.
It is not applied with paint, nor is it applied with an applicator.
Essentially, we take a 5 gallon bucket of compound and add 1/2 cup of flat white latex paint to it. Mix it with a mixing-paddle (plaster type) till blended in evenly.
We then use a paint roller and basic roller cover with a pole attached. Apply the compound over a 4x4 area (for beginners) and then use a plastic trowel (purchased at wallboard supply stores - KAMCO is in MA)
holding the plastic trowel at the 'proper' angle, you lightly smooth out the peaks of the compound in a random pattern. Applying mild pressure only to bring the peaks down slightly.
This is not exactly a DIYer project. It really is something that takes doing about 30 + ceilings to 'start' to get the hang of it, and have it look decent. You may also want to consider getting an estimate to have it done. If not done right, you will be kicking yourself for attempting it, because it will not look anything like the ceilings that were already done by a pro. Remember, whatever you do to a ceiling -stands out very noticably...
